Texture seam
Continued from this topic: Light seam - Apps / Create - NVIDIA Developer Forums
I think there must something wrong happened to the model’s normal when exporting to USD from Blender using the Omniverse addon.
This is the normal in Blender:
This is the normal in Omniverse Create after opening the exported USD:
This results a seam:
Magic happens when I turn on this and use with subdivision:
@lehuan5062 could you try changing Normal & Tangent Space Generation Mode to CPU instead? That should be a better fix. These seams should go away for GPU mode too in the next release.
Thank you, it fixed the issue!
