I have tried many experiments, and when installing version 5.0+(Ubuntu 20.04) of Jetpack, it can display the correct connected display information. However, when I installing version 4.0+(Ubuntu 18.04), it cannot display all the connected display information. Whether my HDMI or DP are connected or not, the information displayed by the xrandr command is shown in the following figure:
Are you sure you have a physical monitor connected there? For example, if it is really working with our driver, xrandr will show either “DP-0” or “HDMI-0”. But that does not appear in your xrandr. It is more like there is a fixed value got hacked in your xorg setting.
I am very certain that the monitor has been connected. With the same operation, Jetpack 5.0+can display information similar to “DP-0” or “HDMI-0”. If my configuration is incorrect, can you provide me with some information for comparison and debugging?
Custom board, but since I installed JetPack 5.0+, it can now display “DP-0” and “HDMI-0”. How should this be explained?
Currently there is one, but even two are connected, and the ‘xrand’ command yields the same result
