JJONGSS
#1
I implemented HDMI and DP ports by referring to the P3509-A1 circuit. The HDMI port works, but the DP port doesn’t.
It is a symptom that is not recognized by the monitor.
If the schematic and impedance matching are the same as the P3509-A1, what should I do?
Which jetpack release are in use?
Sounds weird. Any dmesg to share here? Please remember to plug the DP monitor before dumping log.
JJONGSS
#6
When the DP is connected, the monitor confirms that there is no signal.
I thought you asked for the jet pack version, so I showed it.
So where is your dmesg?
Do you know what I am asking for? Any software guy there working on Linux kernel?
