My platform is jeston agx orin developer kit. Today, I found that the network port does not work after power-on, and it is the same after multiple restarts.
It is speaking of the PHY, the physical interface. Is the wired ethernet disconnected and reconnected ever? I suggest checking the connector for bent pins and debris. This could include an issue at the remote end, e.g., where the cable connects to a switch or router, and not just the PHY of the Jetson. If you have more than one cable, and at the remote end more than one socket, try changing cables and sockets. You could even try to see if it panics with nothing connected to the ethernet but a cable going to nowhere.
