The Franka gripper failed to grasp a deformable object
I want to simulate a gripper grasping a deformable object. But the deformable object slipped from the gripper.
The Franka robot model is from the <Follow Target> in <Isaac Examples>. The deformable object is a cube created by Isaac. I tried to set a large “Dynamic Friction” value in “Deformable Body Material” which the deformable object used. Meanwhile, “Static Friction” and “Dynamic Friction” in “Rigid Body Material” which the “panda_leftfinger” and “panda_rightfinger” used also have large values. The gripper in Franka still failed to grasp the deformable object. The deformable object was still on the ground plane.
How can I simulate the gripper grasping the deformable object successfully?
Any help will be appreciated.
The video shows the grasping:
The value of the friction:
Hi @yang_si_hang
I encourage you to take a look at the Franka Deformable physics demo and inspect the physicsScene properties, deformable materials, and other elements that may help you to adjust your simulation setup better.
Thanks for your reply!
I tried to open the <Franka Deformable> in <Complex Showcases> from <Demo Scenes> but failed. Any Demos in <Complex Showcases> not able to be opened. The Demos in other directories can run successfully, such as <Deformables> and <Rigid Bodies>.
The Isaac Sim terminal reported some warnings:
2022-12-30 14:37:22 [51,723ms] [Warning] [omni.client.plugin]  HTTP Client: provider_http: CC-493: Request through cache failed. Retrying without cache for https://omniverse-content-staging.s3.us-west-2.amazonaws.com/.cloudfront.toml
2022-12-30 14:37:22 [51,723ms] [Warning] [omni.client.plugin]  HTTP Client: omniclient: CC-873: Bypassing cache until the application is restarted
2022-12-30 14:37:25 [55,444ms] [Warning] [rtx.neuraylib.plugin] EntityResolver: Unable to resolve ./df.mdl
2022-12-30 14:37:25 [55,444ms] [Warning] [rtx.neuraylib.plugin] Entity Resolver: FAILED  .::df  <--->  ::ZDDhttps_3A_2F::ZFFomniverse_2Dcontent_2Dstaging_2Es3_2Eus_2Dwest_2D2_2Eamazonaws_2Ecom::DoNotDelete::PhysicsDemoAssets::Z2E_3104_2E1::FrankaDeformable::materials::df  (NULL)
2022-12-30 14:37:25 [55,444ms] [Warning] [rtx.neuraylib.plugin] EntityResolver: Unable to resolve ./base.mdl
2022-12-30 14:37:25 [55,444ms] [Warning] [rtx.neuraylib.plugin] Entity Resolver: FAILED  .::base  <--->  ::ZDDhttps_3A_2F::ZFFomniverse_2Dcontent_2Dstaging_2Es3_2Eus_2Dwest_2D2_2Eamazonaws_2Ecom::DoNotDelete::PhysicsDemoAssets::Z2E_3104_2E1::FrankaDeformable::materials::base  (NULL)
2022-12-30 14:37:25 [55,445ms] [Warning] [rtx.neuraylib.plugin] EntityResolver: Unable to resolve ./math.mdl
2022-12-30 14:37:25 [55,445ms] [Warning] [rtx.neuraylib.plugin] Entity Resolver: FAILED  .::math  <--->  ::ZDDhttps_3A_2F::ZFFomniverse_2Dcontent_2Dstaging_2Es3_2Eus_2Dwest_2D2_2Eamazonaws_2Ecom::DoNotDelete::PhysicsDemoAssets::Z2E_3104_2E1::FrankaDeformable::materials::math  (NULL)
2022-12-30 14:37:25 [55,446ms] [Warning] [rtx.neuraylib.plugin] EntityResolver: Unable to resolve ./state.mdl
2022-12-30 14:37:25 [55,446ms] [Warning] [rtx.neuraylib.plugin] Entity Resolver: FAILED  .::state  <--->  ::ZDDhttps_3A_2F::ZFFomniverse_2Dcontent_2Dstaging_2Es3_2Eus_2Dwest_2D2_2Eamazonaws_2Ecom::DoNotDelete::PhysicsDemoAssets::Z2E_3104_2E1::FrankaDeformable::materials::state  (NULL)
2022-12-30 14:37:25 [55,446ms] [Warning] [rtx.neuraylib.plugin] EntityResolver: Unable to resolve ./anno.mdl
2022-12-30 14:37:25 [55,447ms] [Warning] [rtx.neuraylib.plugin] Entity Resolver: FAILED  .::anno  <--->  ::ZDDhttps_3A_2F::ZFFomniverse_2Dcontent_2Dstaging_2Es3_2Eus_2Dwest_2D2_2Eamazonaws_2Ecom::DoNotDelete::PhysicsDemoAssets::Z2E_3104_2E1::FrankaDeformable::materials::anno  (NULL)
2022-12-30 14:37:25 [55,447ms] [Warning] [rtx.neuraylib.plugin] EntityResolver: Unable to resolve ./tex.mdl
2022-12-30 14:37:25 [55,447ms] [Warning] [rtx.neuraylib.plugin] Entity Resolver: FAILED  .::tex  <--->  ::ZDDhttps_3A_2F::ZFFomniverse_2Dcontent_2Dstaging_2Es3_2Eus_2Dwest_2D2_2Eamazonaws_2Ecom::DoNotDelete::PhysicsDemoAssets::Z2E_3104_2E1::FrankaDeformable::materials::tex  (NULL)
2022-12-30 14:37:26 [56,332ms] [Warning] [omni.hydra.scene_delegate.plugin] Calling getBypassRenderSkelMeshProcessing for prim /PhysxDeformablesVisualizationMeshes/_World_envs_env_0_extras_extra_0_collision/samplePoints.proto0_prototype_id0 that has not been populated
The Screenshot when the issue occurred is shown below. I couldn’t do any operation in Isaac Sim. Isaac Sim seemed to have no response, So I had to force quit the Isaac Sim.
Any help will be appreciated!
Hi @yang_si_hang
I get those warning messages too.
Just ignore them and wait for the scene to load (it can take some time)…
I tried your method and waited some minutes. The demos in <Complex Showcases> can work now.
Thank you most sincerely!
