The interface enc->setBitrate(bps) can set the video stream bitrate,and it work well.
But sometimes we want to change both the bitrate and the framerate, and the output video stream bitrate not be controled , eg:
enc->setRateControlMode(V4L2_MPEG_VIDEO_BITRATE_MODE_CBR);
enc->setBitrate(1.510001000)
enc->setFrameRate(25, 1); // when we init the encoder,the output bitrate is 1.5M
…//some times later
enc->setBitrate(18001000)
enc->setFrameRate(15, 1); // and we begin to use the 15fps to push the YUV frame to the encoder, but the output bitrate is not 800k
So how to change both fps and framerate,and make sure the encoder bitrate control right?
Runtime configurable parameter string should be of the form:
"f<frame_num1>,<prop_id1><val>,<prop_id2><val>#f<frame_num1>,<prop_id1><val>,<pr
op_id2><val>#..."
e.g. "f20,b8000000,i1#f300,b6000000,r40/1"
