Error executing job with overrides: [‘export.checkpoint=/results/run/act03/rtdetr_model_latest.pth’, ‘export.onnx_file=/results/run/act03/export/rtdetr_model_latest.onnx’, ‘results_dir=/results/run/act03/’]Traceback (most recent call last):
File “/usr/local/lib/python3.12/dist-packages/nvidia_tao_pytorch/core/decorators/workflow.py”, line 72, in _func
raise e
File “/usr/local/lib/python3.12/dist-packages/nvidia_tao_pytorch/core/decorators/workflow.py”, line 51, in _func
runner(cfg, **kwargs)
File “/usr/local/lib/python3.12/dist-packages/nvidia_tao_pytorch/cv/rtdetr/scripts/export.py”, line 55, in main
run_export(cfg)
File “/usr/local/lib/python3.12/dist-packages/nvidia_tao_pytorch/cv/rtdetr/scripts/export.py”, line 182, in run_export
onnx_export.export_model(model, batch_size,
File “/usr/local/lib/python3.12/dist-packages/nvidia_tao_pytorch/cv/deformable_detr/utils/onnx_export.py”, line 74, in export_model
torch.onnx.export(model, dummy_input, onnx_file,
File “/usr/local/lib/python3.12/dist-packages/torch/onnx/init.py”, line 383, in export
export(
File “/usr/local/lib/python3.12/dist-packages/torch/onnx/utils.py”, line 495, in export
_export(
File “/usr/local/lib/python3.12/dist-packages/torch/onnx/utils.py”, line 1428, in _export
graph, params_dict, torch_out = _model_to_graph(
File “/usr/local/lib/python3.12/dist-packages/torch/onnx/utils.py”, line 1053, in _model_to_graph
graph, params, torch_out, module = _create_jit_graph(model, args)
File “/usr/local/lib/python3.12/dist-packages/torch/onnx/utils.py”, line 937, in _create_jit_graph
graph, torch_out = _trace_and_get_graph_from_model(model, args)
File “/usr/local/lib/python3.12/dist-packages/torch/onnx/utils.py”, line 844, in _trace_and_get_graph_from_model
trace_graph, torch_out, inputs_states = torch.jit._get_trace_graph(
File “/usr/local/lib/python3.12/dist-packages/torch/jit/_trace.py”, line 1498, in _get_trace_graph
outs = ONNXTracedModule(
File “/usr/local/lib/python3.12/dist-packages/torch/nn/modules/module.py”, line 1740, in _wrapped_call_impl
return self._call_impl(*args, **kwargs)
File “/usr/local/lib/python3.12/dist-packages/torch/nn/modules/module.py”, line 1751, in _call_impl
return forward_call(*args, **kwargs)
File “/usr/local/lib/python3.12/dist-packages/torch/jit/_trace.py”, line 138, in forward
graph, _out = torch._C._create_graph_by_tracing(
File “/usr/local/lib/python3.12/dist-packages/torch/jit/_trace.py”, line 129, in wrapper
outs.append(self.inner(*trace_inputs))
File “/usr/local/lib/python3.12/dist-packages/torch/nn/modules/module.py”, line 1730, in _slow_forward
result = self.forward(*input, **kwargs)
File “/usr/local/lib/python3.12/dist-packages/nvidia_tao_pytorch/cv/rtdetr/model/build_nn_model.py”, line 157, in forward
x = self.model(x, targets)
File “/usr/local/lib/python3.12/dist-packages/nvidia_tao_pytorch/cv/rtdetr/model/rtdetr.py”, line 88, in forward
x, proj_feats = self.encoder(feats)
File “/usr/local/lib/python3.12/dist-packages/nvidia_tao_pytorch/cv/rtdetr/model/hybrid_encoder.py”, line 339, in forward
memory = self.encoder[i](src_flatten, pos_embed=pos_embed) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
File “/usr/local/lib/python3.12/dist-packages/nvidia_tao_pytorch/cv/rtdetr/model/hybrid_encoder.py”, line 203, in forward
output = layer(output, src_mask=src_mask, pos_embed=pos_embed)
File “/usr/local/lib/python3.12/dist-packages/nvidia_tao_pytorch/cv/rtdetr/model/hybrid_encoder.py”, line 172, in forward
q = k = self.with_pos_embed(src, pos_embed)
File “/usr/local/lib/python3.12/dist-packages/nvidia_tao_pytorch/cv/rtdetr/model/hybrid_encoder.py”, line 165, in with_pos_embed
return tensor if pos_embed is None else tensor + pos_embed
RuntimeError: The size of tensor a (961) must match the size of tensor b (400) at non-singleton dimension 1
