The network setting and web brower
Please provide the following info:
Hardware Platform: [Example: DRIVE AGX Xavier™ Developer Kit]
Software Version: [Example: DRIVE Software 10]
Host Machine Version: [Example: native Ubuntu 18.04]
SDK Manager Version: [Example: 1.1.0.6343]
After flashing the Dirve OS to the AGX device, it seems that a new desktop with few applications has replaced the old one.
I cannot set the network through system setting, in which only VPN and Proxy can be set.
There is no web browser in the new system.
Please check the topic and see if you’re facing the same problem. Thanks!
The solutions given are "sudo cp /etc/apt/sources.list_default /etc/apt/sources.list sudo apt update $ sudo apt install ", which need connection to the network.
However, there is no network setting gui for eth0 and no browser to login in my network account, so I cannot make the network connection.
Hi @lijie2019,
if you have to have a web browser for the first connection through your proxy server, please try setting your host compute as a bridge to the Drive AGX and by that allowing your to run apt commands.
Alternatively, you can also download the requested debian files to your host computer and copy them to your Drive through ssh to install them locally.
thanks
With the host network bridge, I installed the firefox successfully.
