The ORIN NANO DEVKIT display is abnormal
With ORIN NANO devkit, no matter it is SDKmanager or balenaEtcher, the system display is unstable, and there is only a small probability that it can enter the desktop. However, ssh can be used to connect to the system remotely. However, our actual development requires a graphical interface. Is there any way to find out the specific cause?
The following interface is displayed when the VNC connection is used.
Here is the complete dmesg information.
jetsonOrinNano_2023-07-27_10_45_08.log (146.4 KB)
你們現在是headless,想要用VNC進GUI環境嗎?如果接實體螢幕顯示是正常的嗎?
麻煩也給一下Xorg的log
/var/log/Xorg.0.log
实际上我们是需要GUI界面,VNC只是为了试一下能不能连上GUI界面。
Xorg.0.log (48.4 KB)
你們用的是Orin Nano官方的DevKit沒錯嗎?
usecase是有接螢幕但是GUI出不來?
Xorg後半段的log看起來螢幕訊號非常頻繁的連上又中斷,要不要換一台螢幕或是線試試看
是的,接上了,但是没有GUI出来
VNC is unavailable.
Any good suggestions?
lsmod | grep nvidia看看nvidia和nvidia_modeset是不是都有被load起來,如果都有的話應該就不是軟體的問題,請你們先試試看換一組螢幕/線、還是一樣的話我們再討論
或者forum上也有非常多user在討論dummy display
f93c6c56779c870fd8cc520afadc924
我们更换一套显示跟线再试一下。
