post can’t be empty
Hi
You can run tegrastats that will show power data on each module.
The power consumption is depend on use case, working loading, application type…
I also have other question.Can you share the consumption data of Jetson AGX Xavier in differential use case?Thanks a lot!
Hi Username1,
We don’t have the consumption data to provide, you may need to do the measurement by yourself.
