As suggested, I read through the related document. In my understanding, one eMMC NX module in sleep state is supposed to consume around same power. But, in the reality, same eMMC module was tested on Li Nano carrier board, and our customized board, tegrastats presents different results:
You can see the total power consumption with the same NX module on two boards: 1377mW vs 2200mW.
I have two questions about the testing results:
How come the power consumption difference is so big? I got totally confused about it.
Also, in each case, the total power consumption is much greater than the sum of CPU_GPU_CV & VDD_SOC. In sleep state, how come other parts of the NX module have consumed that much power?
We are trying to build battery powered productions with NX module, and the power consumption is very important in design consideration.
Thanks Jerry, I will check the utility you recommended. But, if possible, could you help analyze those two questions about the “tegrastats” tool? I got totally confused about my testing results.
I read ina3221 datasheet, and check the values in /sys/bus/i2c/drivers/ina3221x/7-0040/iio:device0
It looks like the power consumption shown in “tegrastats” command should include those from carrier board also, not just consumed by the module. Can you share the schematics connection within jetson xavier nx module related to ina3221? The attached is my guess about the connection. Thanks a lot!!
