The speed of DS90UB960 is set to 1600M to Orin, and there is no picture in the Orin.How to solve it?
The data path is as following.
camera sensor---------->DS90UB953---------->DS90UB960---------->Orin
If I set the speed of DS90UB960 to 1200M, the Orin can capture the picture of the camera.And if I set the speed of DS90UB960 to 1600M,there is no picture caputured. I want to set the speed to 1600M because of the need of 4 camera.
Can you tell me how to solve it?
Did you modify pix_clk_hz/serdes_pix_clk_hz in dts??
If don’t boost the clocks to try. If still failed get the trace log to check if more informaiton.
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee  /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
