When testing SSD on ORIN 32GB custom carrier, the read/write rate is too slow, as follows:
1、The SSD test script is as follows:
2、use PCIE4.0 SSD speed measurement, the rate is as follows:
3、 use PCIE3.0 SSD speed measurement, the rate is as follows:
kayccc
August 15, 2023, 12:26am
3
Which JetPack you’re using?
Have you set the system to the maxmize performance by NVPModel?
1, I use: Jetson agx orin32gb module.
2. About “NVPModel”, I don’t know where it is set
Do you use Jetpack 5.1.1 or 5.1.2?
I use Jetpack 5.1.1。
Here’s what we just tested in different power modes:(这是刚刚在不同的功耗模式下测试的结果:)
Do you observe the issue when connecting the NVMe SSD card to M.2 M-Key slot on AGX Orin developer kit? Please connect the card to developer kit and try to reproduce the issue. To clarify if it is specific to using custom board.
system
Closed
September 12, 2023, 7:59am
9
