I’m using 3D Studio Max DCC plug-in for PhysX 3-4-2 and 3ds Max 2015
My steps:
- Create Dynamic Rig
- select the left knee joint which is between the left thigh and the left calf.
- set Constraint Limits as Hard Limits
- Start simulation
I can see the thigh and the calf moves exceeding the Swing Y Limits.
I also exported PhysXScene to see the parameters
nvpx.PrepExportPhysXScene true "RepX"
nvpx.PrepExportPhysXProj true
nvpx.ExportPhysXProject "test" "exported" ""
The exported file shows the knee joint’s Stiffness and Damping of SwingLimit are always 0.1 and 0.2, like this
<SwingLimit >
<Restitution >0</Restitution>
<BounceThreshold >0.5</BounceThreshold>
<Stiffness >0.1</Stiffness>
<Damping >0.2</Damping>
<ContactDistance >0.0617253</ContactDistance>
<YAngle >1.23451</YAngle>
<ZAngle >1.17549e-038</ZAngle>
</SwingLimit>
After trying all parameters combination I found that there is no way to set a limited joint’s contraint limits as hard limits, or say there is no way to change Stiffness and Damping of SwingLimit
