Such as title. I want to simulate a linear spring. I built a linear joint, and give the limit is 0 to 0, but a limit stiffness. It did not work.
ltorabi
2
please see if this doc is helpful for you: https://docs.nvidia.com/gameworks/content/gameworkslibrary/physx/guide/Manual/Articulations.html
Related topics
| Isaac Sim 4.5 PhysX SphericalJoint soft‐limit springCompliance/Damping not producing expected elastic return | 2 | 198 | May 28, 2025 | |
| Create a custom joint | 0 | 603 | December 21, 2016 | |
| Simulation disrespecting joint limits | 17 | 2221 | April 10, 2024 | |
| Revolute joint limits violated in long articulated rod (Isaac Sim 4.5.0) | 3 | 142 | July 31, 2025 | |
| There is no way to set a limited joint's contraint limits as hard limits with Max PhysX plugin-in | 0 | 615 | October 14, 2019 | |
| How to create a ball joint with built-in spring effect in Isaac Sim 4.5.0? | 2 | 175 | May 28, 2025 | |
| Rotation limits on custom ball joints ignored when DriveAPI disabled (Isaac Sim 4.5.0 / PhysX Articulation) | 3 | 130 | July 31, 2025 | |
| How to simulate the spring in Isaac Sim? | 2 | 1338 | April 5, 2024 | |
| How to simulate "wires" with a physical system? | 11 | 1876 | September 28, 2023 | |
| Does IsaacSim support soft joint limits? | 2 | 179 | October 31, 2024 |
