I have new ThinkPad X1 Gen3, with dual boot - Win10 + Ubuntu 20.04. I’m trying to configure an external Asus 28" monitor to work as as extended display in Ubuntu. The monitor is being recognized by the system, but always remains blank. The same setup works fine on Win10.
SecureBoot is disabled.
I’ve installed nvidia drivers v460. Upgrade to (untested) v465 did not help, so I reverted back.
Bug report is attached, some debug information is pasted below and attached.
Any help will be appreciated.
anton@Anton-X1:~$ sudo lshw -c video
*-display
description: VGA compatible controller
product: NVIDIA Corporation
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:179 memory:ad000000-adffffff memory:80000000-8fffffff memory:90000000-91ffffff ioport:3000(size=128) memory:ae080000-ae0fffff
*-display
product: UHD Graphics
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
logical name: /dev/fb0
version: 05
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=i915 latency=0 mode=3840x2160 visual=truecolor xres=3840 yres=2160
resources: iomemory:600-5ff iomemory:400-3ff irq:177 memory:6040000000-6040ffffff memory:4000000000-400fffffff ioport:4000(size=64) memory:c0000-dffff
anton@Anton-X1:~$
anton@Anton-X1:~$ nvidia-smi
Thu Jul 1 19:27:29 2021
| NVIDIA-SMI 460.80 Driver Version: 460.80 CUDA Version: 11.2 |
| | | MIG M. |
| 0 GeForce GTX 165... Off | 00000000:01:00.0 On | N/A |
| N/A 37C P8 4W / N/A | 1034MiB / 3911MiB | 11% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1008 G /usr/lib/xorg/Xorg 230MiB |
| 0 N/A N/A 1586 G /usr/lib/xorg/Xorg 557MiB |
| 0 N/A N/A 1758 G /usr/bin/gnome-shell 94MiB |
| 0 N/A N/A 2855 G gnome-control-center 1MiB |
| 0 N/A N/A 2907 G ...AAAAAAAAA= --shared-files 135MiB |
anton@Anton-X1:~$
nvidia-bug-report.log.gz (383.7 KB)
