[Thor] Boot stalls and does not load into X
I recently upgraded my Jetson Thor from JetPack 7.1 to JetPack 7.2.1 (39.2.1-gcid-46758480) using SDK Manager directly on the Thor. The upgrade seemed to go fine and the system was working well afterwards including subsequent reboot.
About a day later upon reboot I was unable to load into the GUI upon boot. The boot would stall as shown in the image. The circumstances leading up to this were I came back to the system which was locked, I entered the password, it froze with the characters asterisked, and I rebooted the system. Subsequent reboots resulted in the same behavior - the boot stalled and I could not enter X. It seemed to stall just as it was about to try beginning to load the GUI.
I was able to login to the system (outside the GUI) switching profiles using Ctrl-Alt-F2. But I could not start X. I have the Thor connected to a Dell 1920x1080 resolution display using the DisplayPort cable. I have not had prior issues with the GUI on this system.
What do you recommend for getting the GUI operational once again, as I would like to preserve my data and not reflash if possible.
If you can, run following and post dmesg.txt here.
sudo dmesg |tee dmesg.txt
Please provide the serial console log:
thor_dmesg.txt (123.7 KB)
Here is the dmesg per your request.
serial_log.txt (147.1 KB)
Here is the serial console log per your request. Thank you!
You could try reinstalling some of the video / graphics related debian packages:
sudo apt update
sudo apt install --reinstall \
 gdm3 gnome-session-bin gnome-settings-daemon mutter mutter-common mutter-common-bin \
 libmutter-14-0 xwayland xserver-xorg xserver-xorg-core
sudo reboot
# If that didn't help then:
 nvidia-l4t-vulkan-sc-openrm nvidia-l4t-cuda-openrm nvidia-l4t-init-openrm \
 nvidia-l4t-video-codec-openrm nvidia-l4t-vulkan-sc-openrm nvidia-l4t-weston
sudo reboot
Or, bypass GNOME/GDM entirely and see whether Xorg can start:
sudo systemctl stop gdm3
startx
I tried reinstalling these packages as you described above but the behavior is unchanged.
I also tried your suggesting of bypassing GNOME/GDM and starting Xorg. When I do that, it also fails. It seems to try to go into a graphical environment - black screen for a second or two like it’s trying to go graphical then exits back to the command prompt . Says Could not resolve keysym XF86NavInfoErrors from xkbcomp are not fatal to the X server xinit: connection to X server lost
can you post your /var/log/Xorg.0.log ?
[ 246.104]
X.Org X Server 1.21.1.11
X Protocol Version 11, Revision 0
[ 246.106] Current Operating System: Linux thor 6.8.12-1021-tegra #1 SMP PREEMPT Thu Aug 6 21:56:04 PDT 2026 aarch64
[ 246.107] Kernel command line: root=PARTUUID=139bc031-a62f-4e76-9abe-382053a6c09c rw rootwait rootfstype=ext4 mminit_loglevel=4 earlycon=tegra_utc,mmio32,0xc5a0000 console=tty0 console=ttyUTC0,115200 clk_ignore_unused firmware_class.path=/etc/firmware fbcon=map:0 nospectre_bhb efi=runtime bl_prof_dataptr=6225920@0x2008010000 bl_prof_ro_ptr=65536@0x20 bl_prof_dataptr=6225920@0x2004010000 bl_prof_ro_ptr=65536@0x2004000000
[ 246.109] xorg-server 2:21.1.12-1ubuntu1.8 (For technical support please see Open source support with enterprise-grade SLAs | Ubuntu)
[ 246.109] Current version of pixman: 0.42.2
[ 246.111] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 246.111] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 246.113] (==) Log file: “/var/log/Xorg.0.log”, Time: Mon Sep 28 06:10:08 2026
[ 246.114] (==) Using config file: “/etc/X11/xorg.conf”
[ 246.115] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 246.115] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 246.115] (==) No Layout section. Using the first Screen section.
[ 246.115] (==) No screen section available. Using defaults.
[ 246.116] (
) |–>Screen “Default Screen Section” (0)
[ 246.116] () | |–>Monitor “”
[ 246.116] (==) No device specified for screen “Default Screen Section”.
Using the first device section listed.
[ 246.116] (
) | |–>Device “Tegra0”
[ 246.116] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 246.116] (**) Allowing byte-swapped clients
[ 246.116] (==) Automatically adding devices
[ 246.116] (==) Automatically enabling devices
[ 246.116] (==) Automatically adding GPU devices
[ 246.116] (==) Automatically binding GPU devices
[ 246.116] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 246.116] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 246.116] Entry deleted from font path.
[ 246.116] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 246.116] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 246.116] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 246.116] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 246.116] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 246.116] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 246.116] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 246.116] (II) Loader magic: 0xaaaab5700010
[ 246.116] (II) Module ABI versions:
[ 246.116] X.Org ANSI C Emulation: 0.4
[ 246.116] X.Org Video Driver: 25.2
[ 246.116] X.Org XInput driver : 24.4
[ 246.116] X.Org Server Extension : 10.0
[ 246.118] (++) using VT number 2
[ 246.121] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_32
[ 246.122] (II) xfree86: Adding drm device (/dev/dri/card3)
[ 246.122] (II) Platform probe for /sys/devices/platform/8808c00000.display/drm/card3
[ 246.123] (II) systemd-logind: got fd for /dev/dri/card3 226:3 fd 13 paused 0
[ 246.123] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 246.123] (II) Platform probe for /sys/devices/platform/bus@0/8181200000.host1x/8181200000.host1x.drm/drm/card1
[ 246.124] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 14 paused 0
[ 246.124] (II) xfree86: Adding drm device (/dev/dri/card2)
[ 246.124] (II) Platform probe for /sys/devices/platform/bus@0/d0b0000000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/drm/card2
[ 246.125] (II) systemd-logind: got fd for /dev/dri/card2 226:2 fd 15 paused 0
[ 246.139] (–) PCI:*(1@0:0:0) 10de:2b00:0000:0000 rev 161, Mem @ 0xd0c0000000/16777216
[ 246.139] (WW) “dri” will not be loaded unless you’ve specified it to be loaded elsewhere.
[ 246.139] (II) “glx” will be loaded by default.
[ 246.139] (II) LoadModule: “extmod”
[ 246.139] (II) Module “extmod” already built-in
[ 246.139] (II) LoadModule: “glx”
[ 246.139] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 246.142] (II) Module glx: vendor=“X.Org Foundation”
[ 246.142] compiled for 1.21.1.11, module version = 1.0.0
[ 246.142] ABI class: X.Org Server Extension, version 10.0
[ 246.142] (II) LoadModule: “nvidia”
[ 246.142] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 246.144] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 246.144] compiled for 1.16.99.901, module version = 1.0.0
[ 246.144] Module class: X.Org Video Driver
[ 246.144] (II) NVIDIA dlloader X Driver 595.78 Release Build (r595_00) (buildbrain@74e043fc-6c96-4a54-a660-50b30a72108d-97k4-j97dd) Thu Aug 6 21:57:48 PDT 2026
[ 246.144] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 246.144] (II) systemd-logind: releasing fd for 226:2
[ 246.146] (II) Loading sub module “fb”
[ 246.146] (II) LoadModule: “fb”
[ 246.146] (II) Module “fb” already built-in
[ 246.146] (II) Loading sub module “wfb”
[ 246.146] (II) LoadModule: “wfb”
[ 246.146] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 246.146] (II) Module wfb: vendor=“X.Org Foundation”
[ 246.146] compiled for 1.21.1.11, module version = 1.0.0
[ 246.146] ABI class: X.Org ANSI C Emulation, version 0.4
[ 246.348] (II) systemd-logind: releasing fd for 226:3
[ 246.350] (II) systemd-logind: releasing fd for 226:1
[ 246.350] (II) NVIDIA(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 246.350] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 246.350] (==) NVIDIA(0): RGB weight 888
[ 246.350] (==) NVIDIA(0): Default visual is TrueColor
[ 246.350] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 246.350] () NVIDIA(0): Option “AllowEmptyInitialConfiguration” “true”
[ 246.350] (
) NVIDIA(0): Enabling 2D acceleration
[ 246.350] (II) Loading sub module “glxserver_nvidia”
[ 246.350] (II) LoadModule: “glxserver_nvidia”
[ 246.350] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 246.360] (II) Module glxserver_nvidia: vendor=“NVIDIA Corporation”
[ 246.360] compiled for 1.16.99.901, module version = 1.0.0
[ 246.360] Module class: X.Org Server Extension
[ 246.360] (II) NVIDIA GLX Module 595.78 Release Build (r595_00) (buildbrain@74e043fc-6c96-4a54-a660-50b30a72108d-97k4-j97dd) Thu Aug 6 21:56:44 PDT 2026
[ 246.360] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 246.369] (–) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 246.369] (–) NVIDIA(0): DFP-0
[ 246.369] (–) NVIDIA(0): DFP-1
[ 246.369] (–) NVIDIA(0): DFP-2
[ 246.369] (–) NVIDIA(0): DFP-3
[ 246.543] (II) NVIDIA(0): NVIDIA GPU NVIDIA Thor (GB10B) at PCI:1:0:0 (GPU-0)
[ 246.543] (–) NVIDIA(0): Memory: 0 kBytes
[ 246.543] (–) NVIDIA(0): VideoBIOS:
[ 246.543] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 249.820] (–) NVIDIA(GPU-0): DFP-0: disconnected
[ 249.820] (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 249.820] (–) NVIDIA(GPU-0): DFP-0: 2380.0 MHz maximum pixel clock
[ 249.918] (–) NVIDIA(GPU-0): ViewSonic VX2453 Series (DFP-1): connected
[ 249.918] (–) NVIDIA(GPU-0): ViewSonic VX2453 Series (DFP-1): Internal TMDS
[ 249.918] (–) NVIDIA(GPU-0): ViewSonic VX2453 Series (DFP-1): 600.0 MHz maximum pixel clock
[ 249.918] (–) NVIDIA(GPU-0): DFP-2: disconnected
[ 249.918] (–) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 249.918] (–) NVIDIA(GPU-0): DFP-2: 2380.0 MHz maximum pixel clock
[ 249.918] (–) NVIDIA(GPU-0): DFP-3: disconnected
[ 249.918] (–) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 249.918] (–) NVIDIA(GPU-0): DFP-3: 2380.0 MHz maximum pixel clock
[ 249.963] (==) NVIDIA(0):
[ 249.963] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 249.963] (==) NVIDIA(0): will be used as the requested mode.
[ 249.966] (II) NVIDIA(0): Validated MetaModes:
[ 249.966] (II) NVIDIA(0): “DFP-1:nvidia-auto-select”
[ 249.966] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 250.125] (–) NVIDIA(0): DPI set to (93, 94); computed from “UseEdidDpi” X config
[ 250.125] (–) NVIDIA(0): option
[ 250.125] (EE) NVIDIA(GPU-1): Failed to initialize the NVIDIA graphics device!
[ 250.125] (II) NVIDIA(GPU-1): Deleting GPU-1
[ 250.127] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 250.127] (II) NVIDIA: access.
[ 250.166] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 250.166] (II) NVIDIA(0): may not be running or the “AcpidSocketPath” X
[ 250.166] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 250.166] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 250.166] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 250.166] (II) NVIDIA(0): details, please see the “ConnectToAcpid” and
[ 250.166] (II) NVIDIA(0): “AcpidSocketPath” X configuration options in Appendix B: X
[ 250.166] (II) NVIDIA(0): Config Options in the README.
[ 250.217] (II) NVIDIA(0): Setting mode “DFP-1:nvidia-auto-select”
[ 250.367] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 250.367] (==) NVIDIA(0): Backing store enabled
[ 250.367] (==) NVIDIA(0): Silken mouse enabled
[ 250.367] (==) NVIDIA(0): DPMS enabled
[ 250.367] (II) Loading sub module “dri2”
[ 250.367] (II) LoadModule: “dri2”
[ 250.367] (II) Module “dri2” already built-in
[ 250.367] (II) NVIDIA(0): [DRI2] Setup complete
[ 250.367] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 250.367] (II) Initializing extension Generic Event Extension
[ 250.368] (II) Initializing extension SHAPE
[ 250.368] (II) Initializing extension MIT-SHM
[ 250.368] (II) Initializing extension XInputExtension
[ 250.368] (II) Initializing extension XTEST
[ 250.368] (II) Initializing extension BIG-REQUESTS
[ 250.369] (II) Initializing extension SYNC
[ 250.369] (II) Initializing extension XKEYBOARD
[ 250.369] (II) Initializing extension XC-MISC
[ 250.369] (II) Initializing extension SECURITY
[ 250.369] (II) Initializing extension XFIXES
[ 250.369] (II) Initializing extension RENDER
[ 250.370] (II) Initializing extension RANDR
[ 250.370] (II) Initializing extension COMPOSITE
[ 250.370] (II) Initializing extension DAMAGE
[ 250.370] (II) Initializing extension MIT-SCREEN-SAVER
[ 250.370] (II) Initializing extension DOUBLE-BUFFER
[ 250.371] (II) Initializing extension RECORD
[ 250.371] (II) Initializing extension DPMS
[ 250.371] (II) Initializing extension Present
[ 250.371] (II) Initializing extension DRI3
[ 250.371] (II) Initializing extension X-Resource
[ 250.371] (II) Initializing extension XVideo
[ 250.372] (II) Initializing extension XVideo-MotionCompensation
[ 250.372] (II) Initializing extension SELinux
[ 250.372] (II) SELinux: Disabled on system
[ 250.372] (II) Initializing extension GLX
[ 250.372] (II) Indirect GLX disabled.
[ 250.372] (II) GLX: Another vendor is already registered for screen 0
[ 250.372] (II) Initializing extension XFree86-VidModeExtension
[ 250.372] (II) Initializing extension XFree86-DGA
[ 250.372] (II) Initializing extension XFree86-DRI
[ 250.372] (II) Initializing extension DRI2
[ 250.372] (II) Initializing extension NV-GLX
[ 250.373] (II) Initializing extension NV-CONTROL
[ 250.373] (II) Initializing extension XINERAMA
[ 250.453] (II) config/udev: Adding input device NVIDIA Jetson Thor AGX HDA HDMI/DP,pcm=3 (/dev/input/event5)
[ 250.453] (II) No input driver specified, ignoring this device.
[ 250.453] (II) This device may have been added with another device file.
[ 250.454] (II) config/udev: Adding input device NVIDIA Jetson Thor AGX HDA HDMI/DP,pcm=7 (/dev/input/event6)
[ 250.454] (II) No input driver specified, ignoring this device.
[ 250.454] (II) This device may have been added with another device file.
[ 250.454] (II) config/udev: Adding input device NVIDIA Jetson Thor AGX HDA HDMI/DP,pcm=8 (/dev/input/event7)
[ 250.455] (II) config/udev: Adding input device NVIDIA Jetson Thor AGX HDA HDMI/DP,pcm=9 (/dev/input/event8)
[ 250.455] (II) No input driver specified, ignoring this device.
[ 250.455] (II) This device may have been added with another device file.
[ 250.455] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/event1)
[ 250.455] () USB OPTICAL MOUSE: Applying InputClass “libinput pointer catchall”
[ 250.455] (II) LoadModule: “libinput”
[ 250.456] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 250.457] (II) Module libinput: vendor=“X.Org Foundation”
[ 250.457] compiled for 1.21.1.11, module version = 1.4.0
[ 250.457] Module class: X.Org XInput Driver
[ 250.457] ABI class: X.Org XInput driver, version 24.4
[ 250.457] (II) Using input driver ‘libinput’ for ’ USB OPTICAL MOUSE’
[ 250.516] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 45 paused 0
[ 250.516] (
) USB OPTICAL MOUSE: always reports core events
[ 250.516] () Option “Device” “/dev/input/event1”
[ 250.519] (II) event1 - USB OPTICAL MOUSE: is tagged by udev as: Mouse
[ 250.519] (II) event1 - USB OPTICAL MOUSE: device is a pointer
[ 250.520] (II) event1 - USB OPTICAL MOUSE: device removed
[ 250.520] (II) libinput: USB OPTICAL MOUSE: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 250.520] (
) Option “config_info” “udev:/sys/devices/platform/bus@0/a80aa10000.usb/usb1/1-4/1-4.1/1-4.1:1.0/0003:0000:3825.0001/input/input1/event1”
[ 250.520] (II) XINPUT: Adding extended input device " USB OPTICAL MOUSE" (type: MOUSE, id 6)
[ 250.520] () Option “AccelerationScheme” “none”
[ 250.520] (
) USB OPTICAL MOUSE: (accel) selected scheme none/0
[ 250.520] () USB OPTICAL MOUSE: (accel) acceleration factor: 2.000
[ 250.520] (
) USB OPTICAL MOUSE: (accel) acceleration threshold: 4
[ 250.521] (II) event1 - USB OPTICAL MOUSE: is tagged by udev as: Mouse
[ 250.522] (II) event1 - USB OPTICAL MOUSE: device is a pointer
[ 250.523] (II) config/udev: Adding input device SEMICO USB Keyboard (/dev/input/event2)
[ 250.523] () SEMICO USB Keyboard: Applying InputClass “libinput keyboard catchall”
[ 250.523] (II) Using input driver ‘libinput’ for ‘SEMICO USB Keyboard’
[ 250.523] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 48 paused 0
[ 250.523] (
) SEMICO USB Keyboard: always reports core events
[ 250.523] () Option “Device” “/dev/input/event2”
[ 250.526] (II) event2 - SEMICO USB Keyboard: is tagged by udev as: Keyboard
[ 250.526] (II) event2 - SEMICO USB Keyboard: device is a keyboard
[ 250.526] (II) event2 - SEMICO USB Keyboard: device removed
[ 250.526] (
) Option “config_info” “udev:/sys/devices/platform/bus@0/a80aa10000.usb/usb1/1-4/1-4.2/1-4.2:1.0/0003:1A2C:6004.0002/input/input2/event2”
[ 250.526] (II) XINPUT: Adding extended input device “SEMICO USB Keyboard” (type: KEYBOARD, id 7)
[ 250.526] () Option “xkb_model” “pc105”
[ 250.526] (
) Option “xkb_layout” “us”
[ 250.528] (II) event2 - SEMICO USB Keyboard: is tagged by udev as: Keyboard
[ 250.528] (II) event2 - SEMICO USB Keyboard: device is a keyboard
[ 250.530] (II) config/udev: Adding input device SEMICO USB Keyboard Consumer Control (/dev/input/event3)
[ 250.530] () SEMICO USB Keyboard Consumer Control: Applying InputClass “libinput keyboard catchall”
[ 250.530] (II) Using input driver ‘libinput’ for ‘SEMICO USB Keyboard Consumer Control’
[ 250.530] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 49 paused 0
[ 250.530] (
) SEMICO USB Keyboard Consumer Control: always reports core events
[ 250.530] () Option “Device” “/dev/input/event3”
[ 250.532] (II) event3 - SEMICO USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 250.533] (II) event3 - SEMICO USB Keyboard Consumer Control: device is a keyboard
[ 250.533] (II) event3 - SEMICO USB Keyboard Consumer Control: device removed
[ 250.533] (II) libinput: SEMICO USB Keyboard Consumer Control: needs a virtual subdevice
[ 250.533] (
) Option “config_info” “udev:/sys/devices/platform/bus@0/a80aa10000.usb/usb1/1-4/1-4.2/1-4.2:1.1/0003:1A2C:6004.0003/input/input3/event3”
[ 250.533] (II) XINPUT: Adding extended input device “SEMICO USB Keyboard Consumer Control” (type: MOUSE, id 8)
[ 250.533] () Option “AccelerationScheme” “none”
[ 250.533] (
) SEMICO USB Keyboard Consumer Control: (accel) selected scheme none/0
[ 250.533] () SEMICO USB Keyboard Consumer Control: (accel) acceleration factor: 2.000
[ 250.533] (
) SEMICO USB Keyboard Consumer Control: (accel) acceleration threshold: 4
[ 250.535] (II) event3 - SEMICO USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 250.535] (II) event3 - SEMICO USB Keyboard Consumer Control: device is a keyboard
[ 250.537] (II) config/udev: Adding input device SEMICO USB Keyboard System Control (/dev/input/event4)
[ 250.537] () SEMICO USB Keyboard System Control: Applying InputClass “libinput keyboard catchall”
[ 250.537] (II) Using input driver ‘libinput’ for ‘SEMICO USB Keyboard System Control’
[ 250.537] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 50 paused 0
[ 250.537] (
) SEMICO USB Keyboard System Control: always reports core events
[ 250.537] () Option “Device” “/dev/input/event4”
[ 250.539] (II) event4 - SEMICO USB Keyboard System Control: is tagged by udev as: Keyboard
[ 250.539] (II) event4 - SEMICO USB Keyboard System Control: device is a keyboard
[ 250.540] (II) event4 - SEMICO USB Keyboard System Control: device removed
[ 250.540] (
) Option “config_info” “udev:/sys/devices/platform/bus@0/a80aa10000.usb/usb1/1-4/1-4.2/1-4.2:1.1/0003:1A2C:6004.0003/input/input4/event4”
[ 250.540] (II) XINPUT: Adding extended input device “SEMICO USB Keyboard System Control” (type: KEYBOARD, id 9)
[ 250.540] () Option “xkb_model” “pc105”
[ 250.540] (
[ 250.542] (II) event4 - SEMICO USB Keyboard System Control: is tagged by udev as: Keyboard
[ 250.542] (II) event4 - SEMICO USB Keyboard System Control: device is a keyboard
[ 250.543] (II) config/udev: Adding input device gpio-keys (/dev/input/event0)
[ 250.543] () gpio-keys: Applying InputClass “libinput keyboard catchall”
[ 250.543] (II) Using input driver ‘libinput’ for ‘gpio-keys’
[ 250.544] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 51 paused 0
[ 250.544] (
) gpio-keys: always reports core events
[ 250.544] () Option “Device” “/dev/input/event0”
[ 250.545] (II) event0 - gpio-keys: is tagged by udev as: Keyboard
[ 250.545] (II) event0 - gpio-keys: device is a keyboard
[ 250.545] (II) event0 - gpio-keys: device removed
[ 250.545] (
) Option “config_info” “udev:/sys/devices/platform/gpio-keys/input/input0/event0”
[ 250.545] (II) XINPUT: Adding extended input device “gpio-keys” (type: KEYBOARD, id 10)
[ 250.545] () Option “xkb_model” “pc105”
[ 250.545] (
[ 250.546] (II) event0 - gpio-keys: is tagged by udev as: Keyboard
[ 250.546] (II) event0 - gpio-keys: device is a keyboard
[ 250.547] (II) config/udev: Adding input device NVIDIA Jetson Thor AGX APE Headset Jack (/dev/input/event9)
[ 250.547] () NVIDIA Jetson Thor AGX APE Headset Jack: Applying InputClass “libinput keyboard catchall”
[ 250.547] (II) Using input driver ‘libinput’ for ‘NVIDIA Jetson Thor AGX APE Headset Jack’
[ 250.548] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 52 paused 0
[ 250.548] (
) NVIDIA Jetson Thor AGX APE Headset Jack: always reports core events
[ 250.548] () Option “Device” “/dev/input/event9”
[ 250.549] (II) event9 - NVIDIA Jetson Thor AGX APE Headset Jack: is tagged by udev as: Keyboard Switch
[ 250.549] (II) event9 - NVIDIA Jetson Thor AGX APE Headset Jack: device is a keyboard
[ 250.549] (II) event9 - NVIDIA Jetson Thor AGX APE Headset Jack: device removed
[ 250.549] (
) Option “config_info” “udev:/sys/devices/platform/sound/sound/card1/input9/event9”
[ 250.549] (II) XINPUT: Adding extended input device “NVIDIA Jetson Thor AGX APE Headset Jack” (type: KEYBOARD, id 11)
[ 250.549] () Option “xkb_model” “pc105”
[ 250.549] (
[ 250.550] (II) event9 - NVIDIA Jetson Thor AGX APE Headset Jack: is tagged by udev as: Keyboard Switch
[ 250.551] (II) event9 - NVIDIA Jetson Thor AGX APE Headset Jack: device is a keyboard
[ 250.559] () SEMICO USB Keyboard Consumer Control: Applying InputClass “libinput keyboard catchall”
[ 250.559] (II) Using input driver ‘libinput’ for ‘SEMICO USB Keyboard Consumer Control’
[ 250.559] (II) systemd-logind: returning pre-existing fd for /dev/input/event3 13:67
[ 250.559] (
[ 250.559] () Option “Device” “/dev/input/event3”
[ 250.559] (II) libinput: SEMICO USB Keyboard Consumer Control: is a virtual subdevice
[ 250.559] (
[ 250.559] (II) XINPUT: Adding extended input device “SEMICO USB Keyboard Consumer Control” (type: KEYBOARD, id 12)
[ 250.559] () Option “xkb_model” “pc105”
[ 250.559] (
[ 250.655] () Option “fd” “45”
[ 250.655] (II) event1 - USB OPTICAL MOUSE: device removed
[ 250.655] (
) Option “fd” “48”
[ 250.655] (II) event2 - SEMICO USB Keyboard: device removed
[ 250.655] () Option “fd” “49”
[ 250.655] (
) Option “fd” “50”
[ 250.655] (II) event4 - SEMICO USB Keyboard System Control: device removed
[ 250.655] () Option “fd” “51”
[ 250.655] (II) event0 - gpio-keys: device removed
[ 250.655] (
) Option “fd” “52”
[ 250.655] (II) event9 - NVIDIA Jetson Thor AGX APE Headset Jack: device removed
[ 250.655] (**) Option “fd” “49”
[ 250.655] (II) event3 - SEMICO USB Keyboard Consumer Control: device removed
[ 250.667] (II) UnloadModule: “libinput”
[ 250.668] (II) systemd-logind: not releasing fd for 13:67, still in use
[ 250.668] (II) UnloadModule: “libinput”
[ 250.668] (II) systemd-logind: releasing fd for 13:73
[ 250.668] (II) systemd-logind: releasing fd for 13:64
[ 250.669] (II) UnloadModule: “libinput”
[ 250.669] (II) systemd-logind: releasing fd for 13:68
[ 250.670] (II) UnloadModule: “libinput”
[ 250.670] (II) systemd-logind: releasing fd for 13:67
[ 250.670] (II) systemd-logind: releasing fd for 13:66
[ 250.671] (II) UnloadModule: “libinput”
[ 250.671] (II) systemd-logind: releasing fd for 13:65
[ 250.894] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 250.938] (II) Server terminated successfully (0). Closing log file.
Hi @mike.mueller1,
Thanks for the dmesg, serial log and Xorg.0.log. :
  • In Xorg.0.log the NVIDIA X driver loads, finds your monitor and sets the mode, and the server then ends with Server terminated successfully (0). So Xorg can start. That points at the desktop session (GDM / GNOME Shell, or your user’s session state) rather than the display driver.
To narrow it down, please run the following from the Ctrl-Alt-F2 console and post the output:
  1. Free space (a full disk or a full home directory can make the lock screen and login hang):
    df -h / /home
    df -i /
  2. GDM and session errors from the failed boot:
    sudo journalctl -b -u gdm --no-pager | tail -n 150
    journalctl -b --no-pager | grep -iE "gnome-shell|gdm|segfault|coredump" | tail -n 100
  3. Check whether it is your user account or the system. Create a test user and try to log in to the GUI with it:
    sudo adduser testuser
    sudo systemctl restart gdm3
    If the GUI works for testuser, the problem is in your own user’s configuration. Your data is not affected. Back up first, then move the per-user settings aside and log in again:
    mkdir -p ~/gui-backup
    mv ~/.config/dconf ~/.cache ~/gui-backup/
  4. Your Xorg.0.log shows a ViewSonic VX2453 on DFP-1, which is the HDMI/TMDS output, but you mentioned a Dell monitor on DisplayPort. Please tell us which monitor is connected to which port on the Thor, and whether any adapter is involved.
  5. The output of cat /etc/nv_tegra_release and apt list --installed 2>/dev/null | grep -E "nvidia-l4t-core|nvidia-open|gdm3|gnome-shell".
Ultimately I got this resolved by reinstalling some of the Xorg related packages associated with Ubuntu.
Thanks,
Mike
