THOR Temperature Tolerance
Hi NV Support Team
For thermal test:
We find two Thor mode woring in same loading(sw stress test case)
the temperature senor report GPU about 5 degree tolerance.
My query :
If all thor module working in same loading.
How about the thor temperatue tolerance value? +/3 degree?
e.g.
Yutai
Assuming both Thor modules are at the same temperature, a 5 degree spread is possible given the +/-3 degree temperature sensor uncertainty. For example, if the acutal temperature is X and one Thor reads X+2.5°C and the other Thor reads X-2.5°C, the sensors are still within the uncertainty tolerance but the difference in sensor readings is 5°C. Worst case for the same actual temperature, you could see 6°C spread if one reads +3° and the other reads -3°.
THANKS @ChrisB_NV
