Do you have a thermal simulation model (*.pdml) available?
We can find that the Jetson Thor TMP is 130W. How is this 130W distributed? Can you provide a detailed breakdown of the 130W allocation?
Based on the thermal design guide, is it correct to say that with a θjp of 0.231, the temperature difference between Tj and Tttp is roughly 30 degrees under the MaxN unbalanced workload?
