2.Jetson_TX2 max TMP = 15W right? what test program is NV’s suggestion.
If the program can show temperature, throttling, power…etc its good for us.
3.Below photo is form internet, its Jetson_TX2 inside placement right?
Could you help to check if TMP=15W, what the power distribution on these main chipset?
Why need info of TTP material, due to building Flotherm simualtion model this is a key factor of thermal conductivity. (I predict its should be die casting ADC matel, but need you help to confirm)
Could you help to check what test program is NV’s suggestion, I wanna use the same condition with NV.
There is thermal resistance calculation example and thermal performance estimation in TDG, it should fit your need as other customers had done such work with it.
You can try ‘sudo apt-get install stress’ after nvpmodel is settled.
