But throttle does not response at basic_motion.ipynb at all.
When I assign some value to throttle, some noise occurs.
And clear by 0, noise disappears.
Even I feed power[12V] directly to the gear motor with power supply,
it does not move.
The gear motors do not have any vendor info, I cannot find out contact details.
I am having the same problem, I spanned it for 3 minutes by hand but no success. Could you please advice of any other solution? What type of DC geared motors did you buy?
Similar specifications but a little longer.
Works smart!
I would recommend you to test your motors by Power Supply.
When you feed 12V input, the shaft should spin forward or backward.
Ah, disassemble the motors from the chassis.
M3*6 bolts may disturb the motors. External Image
