JetRacer basic motion : throttle front and back problem
I’m having trouble making jet racers using Jetson Nano.
In basic motion, the throttle is adjusted to a value between -1 and 1.
In my case, if I enter a negative value, the jetracer go forward and positive values ​​work the opposite way.
At first, I thought it would be fine to adjust the reverse on the transmitter.
But it only works when controlled by the transmitter, It was not related to basic motion.
how can i solve this problem?
Can I simply put a negative sign before the throttle value x?
https://github.com/NVIDIA-AI-IOT/jetracer/blob/master/docs/examples.md
Hi khk1262,
Would you explain the exact problem you are facing?
It seems you can just apply a negative throttle gain, but that would not take care of the problem?
Hi khk1262,
We haven’t heard back from you in a couple weeks, so marking this topic closed.
Please open a new forum issue when you are ready and we’ll pick it up there.
