Time of flight Arducam error for jetson nano
eeya@ubuntu:~/Arducam_tof_camera/jetson$ ./Install_dependecies_jetson.sh
[sudo] password for eeya:
Hit:1 Arducam PPA | arducam_ppa linux InRelease
Get:2 https://repo.download.nvidia.com/jetson/common r32.7 InRelease [2,555 B]
Get:3 https://repo.download.nvidia.com/jetson/t210 r32.7 InRelease [2,553 B]
Hit:4 Index of /ubuntu-ports bionic InRelease
Hit:5 Index of /ubuntu-ports bionic-updates InRelease
Hit:6 Index of /ubuntu-ports bionic-backports InRelease
Hit:7 Index of /ubuntu-ports bionic-security InRelease
Fetched 5,108 B in 3s (1,561 B/s)
Reading package lists… Done
Building dependency tree
Reading state information… Done
217 packages can be upgraded. Run ‘apt list --upgradable’ to see them.
arducam-config-parser-dev is already the newest version (0.1.1-1).
arducam-tof-sdk-dev is already the newest version (0.1.2).
arducam-usb-sdk-dev is already the newest version (2.0.1).
The following packages were automatically installed and are no longer required:
apt-clone archdetect-deb bogl-bterm busybox-static cryptsetup-bin
dpkg-repack gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 grub-common
kde-window-manager kinit kio kpackagetool5 kwayland-data kwin-common
kwin-data kwin-x11 libdebian-installer4 libkdecorations2-5v5
libkdecorations2private5v5 libkf5activities5 libkf5attica5
libkf5completion-data libkf5completion5 libkf5declarative-data
libkf5declarative5 libkf5doctools5 libkf5globalaccel-data libkf5globalaccel5
libkf5globalaccelprivate5 libkf5idletime5 libkf5jobwidgets-data
libkf5jobwidgets5 libkf5kcmutils-data libkf5kcmutils5 libkf5kiocore5
libkf5kiontlm5 libkf5kiowidgets5 libkf5newstuff-data libkf5newstuff5
libkf5newstuffcore5 libkf5package-data libkf5package5 libkf5plasma5
libkf5quickaddons5 libkf5solid5 libkf5solid5-data libkf5sonnet5-data
libkf5sonnetcore5 libkf5sonnetui5 libkf5textwidgets-data libkf5textwidgets5
libkf5waylandclient5 libkf5waylandserver5 libkf5xmlgui-bin libkf5xmlgui-data
libkf5xmlgui5 libkscreenlocker5 libkwin4-effect-builtins1 libkwineffects11
libkwinglutils11 libkwinxrenderutils11 libqgsttools-p1 libqt5designer5
libqt5help5 libqt5multimedia5 libqt5multimedia5-plugins
libqt5multimediaquick-p5 libqt5multimediawidgets5 libqt5opengl5
libqt5quickwidgets5 libxcb-composite0 libxcb-cursor0 libxcb-damage0
os-prober python3-dbus.mainloop.pyqt5 python3-icu python3-pam python3-pyqt5
python3-pyqt5.qtsvg python3-pyqt5.qtwebkit
qml-module-org-kde-kquickcontrolsaddons qml-module-qtmultimedia
qml-module-qtquick2 rdate tasksel tasksel-data
Use ‘sudo apt autoremove’ to remove them.
0 upgraded, 0 newly installed, 0 to remove and 217 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up arducam-nvidia-l4t-kernel (4.9.299-tegra-32.7.3-20230111085049) …
1
An unknown error occurred while installing dtoverlays.
dpkg: error processing package arducam-nvidia-l4t-kernel (–configure):
installed arducam-nvidia-l4t-kernel package post-installation script subprocess returned error exit status 255
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
cmake is already the newest version (3.10.2-1ubuntu2.18.04.2).
curl is already the newest version (7.58.0-2ubuntu3.24).
1
–2023-10-28 23:00:07-- https://github.com/ArduCAM/MIPI_Camera/releases/download/v0.0.3/install_full.sh
Resolving github.com (github.com)… 20.207.73.82
Connecting to github.com (github.com)|20.207.73.82|:443… connected.
HTTP request sent, awaiting response… 302 Found
Location: https://objects.githubusercontent.com/github-production-release-asset-2e65be/186627215/ebdc0c54-a520-42e6-b4ef-e241b3acfd59?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20231028%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20231028T180008Z&X-Amz-Expires=300&X-Amz-Signature=6f2965bbd2fb08f1a12518cc25ac702afbfb3e45f8965aa803465e0343e0f18a&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=186627215&response-content-disposition=attachment%3B%20filename%3Dinstall_full.sh&response-content-type=application%2Foctet-stream [following]
–2023-10-28 23:00:08-- https://objects.githubusercontent.com/github-production-release-asset-2e65be/186627215/ebdc0c54-a520-42e6-b4ef-e241b3acfd59?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20231028%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20231028T180008Z&X-Amz-Expires=300&X-Amz-Signature=6f2965bbd2fb08f1a12518cc25ac702afbfb3e45f8965aa803465e0343e0f18a&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=186627215&response-content-disposition=attachment%3B%20filename%3Dinstall_full.sh&response-content-type=application%2Foctet-stream
Resolving objects.githubusercontent.com (objects.githubusercontent.com)… 185.199.108.133, 185.199.109.133, 185.199.110.133, …
Connecting to objects.githubusercontent.com (objects.githubusercontent.com)|185.199.108.133|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 4560 (4.5K) [application/octet-stream]
Saving to: ‘install_full.sh.1’
install_full.sh.1 100%[===================>] 4.45K --.-KB/s in 0.007s
2023-10-28 23:00:09 (626 KB/s) - ‘install_full.sh.1’ saved [4560/4560]
./install_full.sh: line 19: warning: command substitution: ignored null byte in input
NVIDIA Jetson Nano Developer Kit
–2023-10-28 23:00:09-- https://github.com/ArduCAM/MIPI_Camera/releases/download/v0.0.3/arducam_links.txt
Location: https://objects.githubusercontent.com/github-production-release-asset-2e65be/186627215/4ac5b449-c429-4ff7-9b3a-b8de7de9654c?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20231028%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20231028T180010Z&X-Amz-Expires=300&X-Amz-Signature=6755ab41d0733e4b46d9b55bdf0a25d5be3478bf484f42521a2a2620790613ee&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=186627215&response-content-disposition=attachment%3B%20filename%3Darducam_links.txt&response-content-type=application%2Foctet-stream [following]
–2023-10-28 23:00:10-- https://objects.githubusercontent.com/github-production-release-asset-2e65be/186627215/4ac5b449-c429-4ff7-9b3a-b8de7de9654c?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20231028%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20231028T180010Z&X-Amz-Expires=300&X-Amz-Signature=6755ab41d0733e4b46d9b55bdf0a25d5be3478bf484f42521a2a2620790613ee&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=186627215&response-content-disposition=attachment%3B%20filename%3Darducam_links.txt&response-content-type=application%2Foctet-stream
Resolving objects.githubusercontent.com (objects.githubusercontent.com)… 185.199.111.133, 185.199.110.133, 185.199.109.133, …
Connecting to objects.githubusercontent.com (objects.githubusercontent.com)|185.199.111.133|:443… connected.
Length: 12077 (12K) [application/octet-stream]
Saving to: ‘arducam_links.txt’
arducam_links.txt 100%[===================>] 11.79K --.-KB/s in 0.001s
2023-10-28 23:00:12 (18.2 MB/s) - ‘arducam_links.txt’ saved [12077/12077]
–2023-10-28 23:00:12-- https://github.com/ArduCAM/MIPI_Camera/releases/download/v0.0.1/arducam-nvidia-l4t-kernel-t210-4.9.299-tegra-32.7.3-20230111085049_arm64.deb
Location: https://objects.githubusercontent.com/github-production-release-asset-2e65be/186627215/c5583b92-ee7a-4a10-a20c-e2ad8f8bc727?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20231028%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20231028T180013Z&X-Amz-Expires=300&X-Amz-Signature=fa4ef9c5b95ef3affe43efa053ebe4f6448c2206fa97f0dced31bdf34fa80eb5&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=186627215&response-content-disposition=attachment%3B%20filename%3Darducam-nvidia-l4t-kernel-t210-4.9.299-tegra-32.7.3-20230111085049_arm64.deb&response-content-type=application%2Foctet-stream [following]
–2023-10-28 23:00:13-- https://objects.githubusercontent.com/github-production-release-asset-2e65be/186627215/c5583b92-ee7a-4a10-a20c-e2ad8f8bc727?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20231028%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20231028T180013Z&X-Amz-Expires=300&X-Amz-Signature=fa4ef9c5b95ef3affe43efa053ebe4f6448c2206fa97f0dced31bdf34fa80eb5&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=186627215&response-content-disposition=attachment%3B%20filename%3Darducam-nvidia-l4t-kernel-t210-4.9.299-tegra-32.7.3-20230111085049_arm64.deb&response-content-type=application%2Foctet-stream
Length: 8222442 (7.8M) [application/octet-stream]
Saving to: ‘arducam-nvidia-l4t-kernel-t210-4.9.299-tegra-32.7.3-20230111085049_arm64.deb’
arducam-nvidia-l4t- 100%[===================>] 7.84M 2.79MB/s in 2.8s
2023-10-28 23:00:17 (2.79 MB/s) - ‘arducam-nvidia-l4t-kernel-t210-4.9.299-tegra-32.7.3-20230111085049_arm64.deb’ saved [8222442/8222442]
(Reading database … 186491 files and directories currently installed.)
Preparing to unpack arducam-nvidia-l4t-kernel-t210-4.9.299-tegra-32.7.3-20230111085049_arm64.deb …
Unpacking arducam-nvidia-l4t-kernel (4.9.299-tegra-32.7.3-20230111085049) over (4.9.299-tegra-32.7.3-20230111085049) …
1
dpkg: error processing package arducam-nvidia-l4t-kernel (–install):
Unknown error, please send the error message to support@arducam.com
I’m using tof arducam for jetson nano commands from this link : Getting started: Arducam ToF Camera for Jetson - Arducam Wiki
I would suggest consult with arducam for this.
