Originally published at: https://developer.nvidia.com/blog/tips-getting-the-most-out-of-the-dlss-unreal-engine-4-plugin/
DLSS is a deep learning, super-resolution network that boosts frame rates by rendering fewer pixels and then using AI to construct sharp, higher-resolution images. Dedicated computational units on NVIDIA RTX GPUs called Tensor Cores accelerate the AI calculations, allowing the algorithm to run in real time. DLSS pairs perfectly with computationally intensive rendering algorithms such…
Is there any way dlss can be used with the movie render queue? Its urgent. Thank you in advance
Hey ar.redzwan
There is no official support for MRQ with the DLSS Plugin. The DLSS Plugin interface only enables DLSS for the main views.
