Hi All -
Just trying out the latest release of DLSS for UE 5.4.2 and I’m unable to render without crashing with DLSS enabled in MRQ (see error below). I have AA=NONE in the MRQ. Am I missing something else?
The DLSS Sample project loaded and runs fine for me.
Tried different DLSS quality settings - they all crash.
Running latest version of Nvidia Driver (555.99).
Any thoughts / suggestions? Thanks!
Assertion failed: Family->GetTemporalUpscalerInterface() == nullptr [File:D:\build++UE5\Sync\Engine\Source\Runtime\Engine\Private\SceneView.cpp] [Line: 1132] ITemporalUpscaler should be set up in FSceneViewExtensionBase::BeginRenderViewFamily()
UnrealEditor_Engine
UnrealEditor_Engine
UnrealEditor_Renderer
UnrealEditor_MovieRenderPipelineRenderPasses
UnrealEditor_MovieRenderPipelineCore
UnrealEditor
UnrealEditor
UnrealEditor
UnrealEditor
UnrealEditor
UnrealEditor
UnrealEditor
kernel32
ntdll
[update] - the crashes happened while testing under a project I recently completed (Canyon River scene).
I compared my Plugin / Project / Editor settings to DLSS Sample project - no differences.
Ran through the “DLSS_Super_Resolution_Quick_Start_Guide” pdf and checked all my CVars - no issues.
So, I decided to create a new project - added some meshes from the starter content - It rendered fine under DLSS - no crashes.
I deleted those meshes, added a Landscape (default values) and dropped in a Water Body River to re-create a very simplistic version of my previous project and rendered it - CRASH.
I deleted the River from my scene (left the Water Body plugin enabled in the project) and rendered again - NO CRASH.
So it seems the DLSS Plugin does not like to render Water Body Actors.
Tested with DLSS 3.7.20 - same issue.
We are facing the same crash when trying to render scenes in Movie Render Queue with DLSS enabled on any setting:
[2025.03.21-09.17.16:448][292]LogWindows: Error: appError called: Assertion failed: Family->GetTemporalUpscalerInterface() == nullptr [File:D:\build++UE5\Sync\Engine\Source\Runtime\Engine\Private\SceneView.cpp] [Line: 1132]
Plugins enabled in project are:
DLSS
DLSSMoviePipelineSupport
StreamlineCore
2025.02.25_UE_5.4_Plugin_4.0.0
@MarkusHoHo
Just an update on my issue with UE Water Body Actors.
I tested this again using the new DLSS 4.0 plugin for UE5.5 and it renders without any issues.
