I tried to boot from usb on Xavier NX with Jetpack5.0.2
I followed ’ To set up a flash drive manually for booting’ (Dev guide) step by step.
I have encounterd error like below.
Finish generating flash package.
/media/aiserver/data/manage_jetpack_version/xavier_nx_502/flashing/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --external-only --direct sdc --skipuid --usb-instance 1-8 --device-instance 0 --flash-only --external-device sda1 -c "tools/kernel_flash/flash_l4t_external.xml" --direct sdc jetson-xavier-nx-devkit-emmc external
* Step 1: Start the host connected device flashing process *
blockdev: cannot open /dev/mmcblk0boot0: No such file or directory
[ 0]: l4t_flash_from_kernel: Starting to create gpt for external device
Active index file is /media/aiserver/data/manage_jetpack_version/xavier_nx_502/flashing/Linux_for_Tegra/tools/kernel_flash/images/external/flash.idx
Number of lines is 13
max_index=12
writing item=1, 9:0:primary_gpt, 512, 19968, gpt_primary_9_0.bin, 16896, fixed-<reserved>-0, bc1689f28717ff5c5c7a2970ef58b7b618510da7
Writing primary_gpt partition with gpt_primary_9_0.bin
Offset is not aligned to K Bytes, no optimization is applied
dd if=/media/aiserver/data/manage_jetpack_version/xavier_nx_502/flashing/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_primary_9_0.bin of=/dev/sdc bs=1 skip=0 seek=512 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0206577 s, 818 kB/s
Writing primary_gpt partition done
Error: Invalid argument during seek for read on /dev/sdc
[ 0]: l4t_flash_from_kernel: Error: partprobe failed. This indicates that:
- the xml indicates the gpt is larger than the device storage
- the xml might be invalid
- the device might have a problem.
Please make correction.
Cleaning up...
Could you tell me how to resolve this issue?
Thank you.
