Flash Xavier NX JP4.4. on external USB drive
I have a Xavier NX emmc modules with 8GB memory connected to our custom carrier board which has a 64GB usb external storage
I want to flash my kernel on USB of the board (JetPack 4.4)
the command i use is:
sudo ./flash.sh jetson-xavier-nx-devkit-emmc sda1
but the board does not boot up as expected.
4.4_flashlog.txt (51.1 KB)
boot log:
4.4_bootlog.txt (13.9 KB)
Have you modified the eeprom value?
some examples like this docs mentioned
https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/HR/JetsonModuleAdaptationAndBringUp/JetsonOrinNxNanoSeries.html#eeprom-modifications
@DavidDDD
which is the corresponding file for JetPack 4.4? I do a grep -nr “cvb_eeprom_read_size” but do not find it.
I am familiar with JP5.1 but i need it for JP4.4
Sorry for mislead.
It’s fine with eeprom.
We need more info, so could you edit Linux_for_Tegra/bootloader/extlinux.conf to remove quiet and attach the flashing log again.
LABEL primary
      MENU LABEL primary kernel
      LINUX /boot/Image
      INITRD /boot/initrd
      APPEND ${cbootargs}
Also how do you prepare the rootfs?
@DavidDDD
4.4_bootlog.txt (11.2 KB)
The board does not boot up as expected.
My use case is that i have a custom carrier board for xavier NX som
the carrier board has an onboard memory of 64 gb which acts as a USB drive and Xavier NX som is 8 gb emmc
i am trying to flash my kernel on 64 gb emmc on the board. from Linux_for_Tegra environment of JP4.4 downloaded from SDK manager
It’s strange with your bootlog.txt.
Do you upload the right one?
@DavidDDD
How to setup username and password for JP4.4 over flashing? The JP5 has a script create_default_user.sh in Linux_for_Tegra/tools/ .
what is the equivalent for JP4.4 i do not see any script
create_default_user.sh supported in JP4.6.6
You could get the file from it.
@DavidDDD
Does the Xavier NX SOM emmc’s data have to be erased in order to boot from external emmc connected to my carrier board?
Hi
Yes, You need backup your data before flashing.
