Topic Description
Detailed Description
IsaacLab ver 4.5
I used both windows and linux on two different setups - the problem persists.
trying to toggle visibility for assets in the franka lift environment(object and robot).
When I try to toggle it either stays visible or invisible.
i’ve tried multiple ways: assetbase.set_visibility, visibilityAttr(), makevisible()
i’ve tried render after the change using env.render() - that also doesn’t work
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here)
i’m trying to get the overlap of prims for semantic segmentation to figure out the distance between these assets. If there’s another way to do that then please tell me.
