Topic Description
Turn off and on visibility with Python code for specific annotations.
Detailed Description
What I am trying to achieve. I created these images in Blender to showcase the end result I want to achieve with Python code inside of Isaac Sim. The main computer vision task related to this synthetic image dataset is to capture the opening of a bin. How I am going about it:
- Creating the bin
- Creating a 2D plane that sits on top of the opening of the bin
- Turn off the visibility of the plane (the opening) only when capturing the RGB images
- Turn on the visibility of the plane (the opening) when capturing the semantic segmentation masks images.
Please how can I do this inside of the script editor?
Thank you
Isaac Sim Version
4.2.0
Operating System
Windows 11
GPU Information
- Model: Nvidia GeForce RTX 4070 Laptop GPU
- Driver Version: 32.0.15.6614
Additional Information
What I’ve Tried
#Paths to the assets
first_asset_path = "/bin1/RL_KLT_6280" # Path to the first asset in the scene
second_asset_path = "/opening/RL_KLT_6280_002" # Path to the second asset in the scene
#Specify the exact position for the second asset relative to the first
second_asset_position = (0, 0, 0) # Adjust as needed
with rep.new_layer():
#Add Default Light
distance_light = rep.create.light(rotation=(315, 0, 0), intensity=3000, light_type="distant")
# Create Camera
camera = rep.create.camera(position=(923.04092, 923.04098, -976.00001))
# Create a render product for the camera
render_product = rep.create.render_product(camera, (1024, 1024))
def load_and_move_assets():
# Load the first asset
first_asset = rep.get.prim_at_path(first_asset_path)
# Define randomization for the first asset's position and rotation
with first_asset:
rep.modify.pose(
position=rep.distribution.uniform((-500, 50, -500), (500, 50, 500)),
rotation=rep.distribution.uniform((0, -180, 0), (0, 180, 0)),
# Load the second asset
second_asset = rep.create.from_usd(second_asset_path, semantics=[('class', 'opening')])
# Parent the second asset to the first asset and set its position relative to the first
rep.modify.parent(second_asset, parent=first_asset)
with second_asset:
rep.modify.pose(position=second_asset_position)
# Set visibility for the second asset
with second_asset:
rep.modify.visibility(render_product=render_product, visible=False, output_type="rgb")
rep.modify.visibility(render_product=render_product, visible=True, output_type="semantic_segmentation")
return first_asset.node, second_asset.node
# Register randomizer for loading and positioning the assets
rep.randomizer.register(load_and_move_assets)
# Setup randomization
with rep.trigger.on_frame(num_frames=100):
rep.randomizer.load_and_move_assets()
# Set up the output writer with the new output directory
writer = rep.WriterRegistry.get("BasicWriter")
writer.initialize(output_dir="C:/Users/elina/Documents/isaac_sim_practice/bin_randomizer_fix/output",
rgb=True,
semantic_segmentation=True,
bounding_box_2d_tight=True)
writer.attach([render_product])
