自制载板
我在试图自制载板,有以下问题。
1.是否直接按照官网提供的Gerber文件加工即可。加工材料选择高速PCB材质。是否有加工要求。
2.给CY4226和EFM8SB1下载程序是通过载板下载还是下载好程序之后再往载板上焊接
3.加工完成之后,如何进行调试载板各模块功能,是通过示波器吗?还是控制端口,有无相关文档
4.我需要用JTAG 边缘检测吗?
不胜感激!
Hi, the devkit docs are for devkit only, suggest custom design to follow the product design guide routing guideline and reference schematic to make the schematic/pcb. You should check with PCB vendor for its detail request. And for the CY4226 and EFM8SB1, you should check with vendor for the info too, they are flashed before ship out. There is tuning guide in DLC for some interface tuning. Jtag is unnecessary.
