你好!
我在flash目录下执行:sudo ./flash.sh jetson-xavier-nx-devkit-emmc mmcblk0p1 ,flash结束之后如图:
之后基本配置之后显示如图:
Which jetpack release is in use here?
jetpack4.4
please try with some new release like jp4.6 or jp4.6.1.
jetpack4.4是我们出厂的系统,不可以随便更改版本的,所以需要解决这个问题
Does this only happen to one module? It sounds like you didn’t hit this issue before?
是的
Please try to use devkit + sdkmanager to flash it and see if it would have issue or not.
I have encountered this issue, the rootcause was that I putted the bsp on NTFS pation. change to ext4 , problem disappeared.
sdkmanager1.7.3.9053 不支持jetpack4.4
我的分区是ext4
