芯片设计问题
目前我们发现mipi信号输入xavier NX 核心板子,信号幅度太低,另外上升沿和下降沿轻微缓慢;
想咨询下,贵司xavier NX的mipi MIPI CSI lanes的接收门限;
评估下mipi CSI的风险;
附件是测试靠近SODIMM260座子附近的测试点的眼图报告;
主要NG项目如下:
1, 测试项目,目前主要fail项是:
彩色相机 camera4,对应xavier NX的CSI4组, 主要fail项目
1.3.11 HS Data TX 20%-80% Rise Time (tR)[Burst Data], 测试结果500ps, 范围要求:小于375ps
1.3.12 HS Data TX 80%-20% Fall Time (tF)[Burst Data], 测试结果559ps, 范围要求:小于375ps
1.4.4 HS Clock TX Differential Voltage(VOD0 Pulse),, 测试结果106mv, 范围要求:140.00 mV <= VALUE <= 270.00mV
黑白相机测试了camera1的,对应xavier NX的CIS0组输入;
主要fail为:
1.3.11 HS Data TX 20%-80% Rise Time (tR)[Burst Data], HS数据的上升沿=350ps,范围是要求小于375ps;
1.3.12 HS Data TX 80%-20% Fall Time (tF)[Burst Data],测试结果为:391ps,范围要求小于375ps;
1.5.4 Data-to-Clock Skew (TSKEW(TX))(Max,Min),抖动测试,,测试结果 172mUIinst ,范围是150;
Welcome to the NVIDIA Developer forums. Your issue should be posted in the Jetson Xavier NX category, I will move it over to the correct forum for you.
Tom K
hello 1753828207,
driver attempts to auto-calibrate by default, there’s cil_settletime to configure it manually , THS settle time of the MIPI lane, unit in nanoseconds.
please check TRM for the details, please search CLK_SETTLE and THS_SETTLE for reference,
you may also check MIPI Alliance Specification for D-PHY for details.
thanks
hi
Hi JerryChang
感谢您的回复;我们仔细看了下, cil_settletime 好像是建立时间的调整??请帮忙确认下细节怎么调整?
其实我们想咨询的是mipi RX的接收电平门限;我们MIPI TX在源端测试是PASS的,,但是经过长距离PCB传输后,靠近NX核心板子座子260P座子附件,信号衰减到了130mv 左右;
hello user9267,
please share the use-case about the distance,
there’s camera use-case with SerDes chips which support long distance, please see-also developer guide, GMSL Protocol.
thanks
The CSI port on Jetson is standard port following MIPI spec. Please follow MIPI spec for threshold.
