The provided information appears to be a part number for a Jetson AGX Orin module.
Breaking down the part number:
2JAO likely refers to the Jetson AGX Orin module series.
64GB indicates that this module has 64GB of memory.
A is the manufacturing major revision, an upper case letter.
B is likely a version number or a code for a specific configuration.
demo might indicate that this is a demo or evaluation version of the module.
1 could be a numeric code or a version number.
A and B are repeated, possibly indicating different configurations or versions.
B300M might refer to a specific thermal solution or a thermal design power (TDP) rating.
2 could be a numeric code or a version number.
A and B are repeated again, possibly indicating different configurations or versions.
112 and 221 could be numeric codes or version numbers.
2HV12V119V might refer to the module’s voltage rating or power requirements.
Comparing this to the provided context, we can see that the Jetson AGX Orin 64GB module is mentioned as a production module with a part number P3701-0005. However, the provided part number 2JAO64GBA Bdemo 1 A B300M 2 A B300M 300M 112 221 2HV12V119V does not match the format of the part numbers mentioned in the context.
It’s possible that this part number is a custom or OEM version of the Jetson AGX Orin 64GB module, or it might be a part number from a different manufacturer or product line. Without more information, it’s difficult to provide a more specific answer.
