Hi NV Support Team
I have a query about Jetson Orin Max power : 60W.
JAO 64GB Maximum Module Power: Up to 60 W from datasheet “DS-10662-001_v1.0 | March 2022”
Can you please share the your condition in 60W test case:
How about the environment temperature in your 60W case. e.g. room 25C or other temperatue?
How about the resource loading in your 60W case. e.g. CPU frequence/ Load percentage, GPU frequency/ Load percentage, DLA DDR frequency, Thermal /Power monitor data…
Hi Trumany
I find the thermal spec in your link, that means jetson orin thermal shutdown is about 105C.
Do you know the 105C is Jetson Orin junction temperatue?
