Jetson AGX orin module 64GB power is up to 60W. what is the actual current on SYS_VIN_HV and SYS_VIN_MV rails when the module is working at 60W? thanks.
Trumany
3
The 60W is a power model, the detail current of HV and MV depends on use case. HV and MV have its own max current limit separately as you can see in module datasheet.
Related topics
| Jetson Orin Max Current | 1 | 1186 | January 5, 2022 | |
| Orin Jetson AGX Power | 1 | 307 | July 8, 2024 | |
| Jetson ORIN power consumption | 5 | 3623 | October 12, 2022 | |
| Jetson AGX Orin Industrial SYS_VIN_SV maximum current draw | 1 | 691 | June 27, 2023 | |
| AGX Orin Industrial Maximum Current Draw | 3 | 174 | April 28, 2026 | |
| How to battery power Jetson Orin Safely | 5 | 3867 | June 14, 2023 | |
| ORIN AGX 64GB Industrial power consumption in each rail | 5 | 350 | August 15, 2024 | |
| Jetson AGX Orin Industrial maximum operating current specifications | 3 | 103 | June 17, 2026 | |
| Power consumption NVIDIA JETSON AGX Orin Industrial | 2 | 149 | October 29, 2025 | |
| Jetson AGX Orin power consumption | 7 | 1819 | September 14, 2022 |
