Torch distributed not supported on Orin?
None of the versions in Index of /compute/redist/jp are supported Torch distributed and I don’t want to use containers.
RuntimeError: Failed to import transformers.modeling_utils because of the following error (look up to see its traceback):
cannot import name ‘ReduceOp’ from ‘torch.distributed’ (/home/jirujun/.local/lib/python3.8/site-packages/torch/distributed/init.py)
Is it integrated into the torch or an extra library?
We only support the PyTorch standard library.
If an extra library is needed, you will need to build it from the source.
