Tracing cuDNN library version 90.6 is currently not supported
First time using Nsight Systems to learn how to profile my code, and I noticed a warning about cuDNN 9 in the Diagnostics Summary - does Nsight Systems not support cuDNN 9?
I should point out that I can see _5x_cudnn_ampere_scudnn_128x64_relu_xregs_large_nn_v1 showing up as kernel in the Timeline and Events View. Does that mean everything is working correctly and I can ignore the warning?
System information:
  • Ubuntu 24.04 (Docker)
  • Python 3.11.11
  • Pytorch 2.5.1 (built from source):
    • CUDA 12.6
    • cuDNN 9.6.0.74-1
  • NVIDIA Nsight Systems 2025.1.1.103-251135427971v0
Full Diagnostics Summary:
Source Process ID Time Description
Daemon -00:00.001 Unable to configure the collection of CPU IP/backtrace samples, context switch data, or event sampling data. Try the ‘nsys status --environment’ command to learn more.
Analysis 00:00.000 Profiling has started.
Daemon 1447 00:00.002 Process was launched by the profiler, see /tmp/nvidia/nsight_systems/quadd_session_101435/streams/pid_1447_stdout.log and stderr.log for program output
Injection 1447 00:00.020 Common injection library initialized successfully.
Analysis 00:00.025 No MMAP events were received for process with pid 1447 before attempting to resolve symbol. This might cause symbols to remain unresolved for the process.
Injection 1447 00:00.028 OS runtime libraries injection initialized successfully.
Analysis 00:00.036 Scheduling information is absent. The thread activity is deduced based on OS runtime libraries traces. This is inaccurate and does not take into account asynchronous interrupts and exception faults.
Analysis 1447 00:00.036 No NVTX events collected. Does the process use NVTX?
Analysis 1447 00:00.036 Number of CUDA events collected: 2.084.
Analysis 1447 00:00.036 Number of OS runtime libraries events collected: 4.095.
Analysis 1447 00:00.036 cuDNN profiling might have not been started correctly.
Analysis 1447 00:00.036 No cuDNN events collected. Does the process use cuDNN?
Injection 1447 00:00.606 Tracing cuDNN library version 90.6 is currently not supported.Loading ‘/opt/nvidia/nsight-systems-cli/2025.1.1/target-linux-x64/libToolsInjectionCuDNN64_90.so’ failed: dlopen hook: ‘/opt/nvidia/nsight-systems-cli/2025.1.1/target-linux-x64/libToolsInjectionCuDNN64_90.so’: cannot open shared object file: No such file or directory.
Injection 1447 00:00.607 cuDNN symbols found in /lib/x86_64-linux-gnu/libcudnn_graph.so.9.6.0 symbol table. No cuDNN trace will be generated from that library. Was cuDNN statically linked?
Injection 1447 00:01.746 Buffers holding CUDA trace data will be flushed on CudaProfilerStop() call. See --flush-on-cudaprofilerstop to control this behavior.
Injection 1447 00:01.761 Loaded CUPTI library: /opt/nvidia/nsight-systems-cli/2025.1.1/target-linux-x64/libcupti.so.12.8
Injection 1447 00:02.071 Enabling trace for device graph launch
Injection 1447 00:02.080 CUDA injection initialized successfully.
Injection 1447 00:02.298 cuDNN symbols found in /lib/x86_64-linux-gnu/libcudnn_graph.so.9.6.0 symbol table. No cuDNN trace will be generated from that library. Was cuDNN statically linked?
Injection 1447 00:02.299 cuDNN symbols found in /lib/x86_64-linux-gnu/libcudnn_graph.so.9.6.0 symbol table. No cuDNN trace will be generated from that library. Was cuDNN statically linked?
Injection 1447 00:02.304 cuDNN symbols found in /lib/x86_64-linux-gnu/libcudnn_graph.so.9.6.0 symbol table. No cuDNN trace will be generated from that library. Was cuDNN statically linked?
Injection 1447 00:03.154 Number of CUPTI events produced: 2.161, CUPTI buffers: 50.
Analysis 00:03.498 Profiling has stopped.
nsys command:
nsys profile -t cuda,nvtx,osrt,cudnn,cublas -x true -o cudnn_test --cuda-event-trace=false python cudnn.py
cudnn.py
import torch
input_tensor = torch.randn(64, 3, 224, 224).cuda()
for _ in range(100):
_ = torch.nn.functional.conv2d(input_tensor, torch.randn(64, 3, 3, 3).cuda())
(Also I tried to tag this topic with cudnn, but it wouldn’t let me)
@liuyis can you give more info about the current status of cuDNN 9?
I checked our support - Nsys indeed does not support CuDNN 9+ trace yet. The latest version we support is CuDNN 8
The reason you see _5x_cudnn_ampere_scudnn_128x64_relu_xregs_large_nn_v1 in the report is because of the CUDA trace feature (--trace=cuda). CuDNN trace, if supported, will provide additional CuDNN API trace.
