Hello Everyone,
I would like to know If I made any mistakes during my tests about the performances of TrafficCamNet on my Jetson AGX Xavier, because NVIDIA declares that with this network on Xavier I can get 420FPS but I did not get any results better than 338 fps through the deepstream sample app.
Nvidia Link:
I configured the pgie file and the deepstream file as following:
pgie config file:
Hello Morgan,
My Jetson Xavier is already working in that way.
I really would like to know if you with your environment can analyse 420 fps with trafficCamNet, because I really can not overcame the 338 fps threshold.
Hello @Morganh
I did not retrain the default trafficCamNet, I am currently using the trafficCamNet int8 precision on my Jetson Xavier.
If you can, could you please tell me if you get 420FPS with the standard model that NVIDIA provided?
Ric
Hello @Morganh
I have a problem with TrafficCamNet, I have compared the results between TrafficCamNet and PeopleNet
and I realised that:
if do not set any tracker and any inference interval TrafficCamNet is faster then PeopleNet as expected but If I set NVDCF tracker PeopleNet become faster then TrafficCamNet, and this behaviour is unexpected, I am going to share with you my results: PLATFORM
