Trying to test for RTSP failed
I am using opencv with gstreamer,to get a rtsp input.
error:
while trying to get the rtsp it occurs that:
(test:107702): GStreamer-CRITICAL **: 18:15:47.076: gst_caps_get_structure: assertion ‘GST_IS_CAPS (caps)’ failed
(test:107702): GStreamer-CRITICAL **: 18:15:47.076: gst_structure_get_int: assertion ‘structure != NULL’ failed
[ WARN:0@30.178] global cap_gstreamer.cpp:1714 open OpenCV | GStreamer warning: cannot query video width/height
(test:107702): GStreamer-CRITICAL **: 18:15:47.076: gst_structure_get_fraction: assertion ‘structure != NULL’ failed
while trying to get frame,it occurs that:
(test:107702): GStreamer-CRITICAL **: 18:19:02.078: gst_sample_get_caps: assertion ‘GST_IS_SAMPLE (sample)’ failed
[ERROR:0@225.181] global cap_gstreamer.cpp:934 retrieveVideoFrame GStreamer: gst_sample_get_caps() returns NULL
my code:
#include <opencv2/opencv.hpp>
#include <iostream>
#include <chrono>
int main()
    using std::chrono::steady_clock;
    typedef std::chrono::milliseconds milliseconds_type;
    const int interval = 15;
    std::stringstream ss;
    std::string rtsp_url = "rtsp://admin:qk123456@192.168.1.100";
    size_t latency = 200;
    size_t frame_width = 1920;
    size_t frame_height = 1080;
    size_t framerate  = 20;
    ss << "rtspsrc location=" << rtsp_url << " latency=" << latency << " ! application/x-rtp, media=video, encoding-name=H264 "
       << "! rtph264depay ! video/x-h264, clock-rate=90000, width=" << frame_width << ", height=" << frame_height << ", framerate="
       << framerate << "/1 ! nvv4l2decoder ! video/x-raw(memory:NVMM), width=" << frame_width << ", height=" << frame_height
       << ", framerate=" << framerate << "/1 ! nvvideoconvert ! video/x-raw, format=BGRx ! videoconvert ! video/x-raw, format=BGR ! appsink";
    std::cout << ss.str() << std::endl;
    cv::VideoCapture cap = cv::VideoCapture(ss.str(), cv::CAP_GSTREAMER);
    if(!cap.isOpened())
        std::cerr << "error to open camera." << std::endl;
        return -1;
    std::cout << cv::getBuildInformation() << std::endl;
    cv::Mat frame ;
    steady_clock::time_point start = steady_clock::now();
    size_t frame_idx = 0;
    while(1)
        bool ret = cap.read(frame);
        if(ret)
            // cv::imwrite("tmp.jpg", frame);
            ++frame_idx;
        if(frame_idx % interval == 0)
            steady_clock::time_point end = steady_clock::now();
            milliseconds_type span = std::chrono::duration_cast<milliseconds_type>(end - start) ;
            std::cout << "it took " << span.count() / frame_idx << " millisencods." << std::endl;
            start = end;
    return 0;
all the index are correct, I can normally use it in another device(jetson nano)
this to device have same environments:
opencv4.8.0
gstreamer2.16.3
jetpack5.1.1
waiting for you reply!
We have later Jetpack 5.1.3 and 6.0GA. You may consider upgrade from 5.1.1 to latest version.
And please apply the RTSP URL to the python sample and see if it works:
Doesn't work nvv4l2decoder for decoding RTSP in gstreamer + opencv - #3 by DaneLLL
And please apply the pipeline with fakesink to gst-launch-1.0 command to ensure the pipeline is valid. Such as:
$ gst-launch-1.0 rtspsrc location=rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvidconv ! video/x-raw, format=(string)BGRx ! videoconvert ! video/x-raw,format=BGR ! fakesink
If it works in gst-launch-1.0 with fakesink, it is supposed to work in cv2.VideoCapture() with appsink
