Trying to train Isaac-Lift-Cube-Franka-v0 example task
I’m running the command below to try and train the Franka arm to lift a cube and bring it to the sampled target position:
./isaaclab.sh -p source/standalone/workflows/rsl_rl/train.py --task Isaac-Lift-Cube-Franka-v0 --num_envs 64 --headless
When I play this policy using
./isaaclab.sh -p source/standalone/workflows/rsl_rl/play.py --task=Isaac-Lift-Cube-Franka-v0 --num_envs=1
The franka arm just moves around slightly but doesn’t go anywhere near the cube, nor does it pick it up. Am I doing something incorrect when training, or is there some value I have to set? All I’ve done is setup IsaacLab and IsaacSim by following the installation instructions, and I haven’t changed any code. I’m in the process of learning so I’m running a few examples right off the bat, so I’m just trying to get Isaac-Lift-Cube-Franka-v0 as listed here to work.
Thank you for your interest in Isaac Lab. To ensure efficient support and collaboration, please submit your topic to its GitHub repo following the instructions provided on Isaac Lab’s Contributing Guidelines regarding discussions, submitting issues, feature requests, and contributing to the project.
We appreciate your understanding and look forward to assisting you.
Hey, I did the same with Isaac-Franka-Reach task and trained it for 1000 epochs as configured in the yaml file. Did you check the mean reward and also the pose errors during training. I think you can also visualise them using Tensorboard. Maybe check if everything went as expected.
feel free to reach out in case of any other questions
