Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model: NVIDIA RTX 3500 Ada Generation
- Driver Version: 570.124.06
Topic Description
Detailed Description
I’m using the standard PickPlaceController from isaacsim.robot.manipulators.examples.franka.controllers with a Franka Emika Panda arm mounted on a Ridgeback mobile base in Isaac Sim 4.5. The controller fails to properly direct the arm to target objects when the Franka is mounted on the Ridgeback.
The issue appears to be that the PickPlaceController._get_target_hs() method doesn’t properly account for the actual Z-position of objects when calculating target heights during pick and place operations. When the Franka is mounted on the Ridgeback, the entire arm is elevated from ground level, causing the controller to target incorrect positions.
The controller works correctly when the Franka is used standalone (not mounted), but fails when mounted on the elevated Ridgeback platform.
Error Messages
No direct error messages, but the controller behaves incorrectly.
Screenshots or Videos
Additional Information
What I’ve Tried
Created a subclass of PickPlaceController that correctly implements the _get_target_hs(picking_z, placing_z) method to properly account for object Z-positions
Created a custom MountedPickPlaceController that extends the standard controller to properly handle Z-positions:
