Tutorial for Building Using a Nvidia Jetson Nano Module from Beginning
Hey everybody. I want to use the jetson nano as a module and attach components like a large screen, battery, usb ports, memory such as an external hard drive to expand the storage, and camera. I see there are 260 pins on it, and do not understand why because I believed it did not insert into anything. Also, for a battery, do I need to do anything different if I want this device to be powered and allow power current to run along the usb ports? Thank you.
Please help me to start correctly, so I use this for a project for building a machine.
Hi, you can start from reading the nano docs in DLC: https://developer.nvidia.com/embedded/downloads
