Hi i’m trying to multi display Deepstream DP AND DP
now i’m using dev kit, so i verifying my pipeline output to the two monitor( HDMI & DP)
but i will insert the module to the other carrier board
it support 2 DP port
but i’m not sure it will work
before the this question i found
i should change the device tree syntax
but i never do that before
can you tell me step by step?
or can you give me a reference ?
i heard i should change
sor / nvdisplay
i need change thd dts/dtb only?
or compile something?
