TX1 and TX2 Video Compression Bit Rates
Could someone from Nvidia provide more fidelity of what the bit rate is for the TX1 and TX2 when video encoding at H.264, H.265, VP8 and VP9 compression rates for one camera sensor at 1080p/60 and for 6 1080p/60 camera sensors?
Also, it would be helpful to know what the bit rate is for the same question for a single 720p/60 sensor and for 6 720p60 camera sensors?
Please refer to https://devtalk.nvidia.com/default/topic/1012826/jetson-tx2/maximum-bitrate-for-multiple-h265-encoding-/post/5163340/#5163340
Hello DaneLLL,
Thanks for your comment. Unfortunately it only gives me some fidelity for H.265 bit rates, can you clarify what the bit rates are for VP8 and VP9 at a specific video resolution/frame rate?
It is general to have 8M 720p60, 12M 1080p60. But every person has different criteria for video quality, you can adjust accordingly.
Hello DaneLLL,
Do you know what the VP8 (and VP9) compressed bit rates are for 1080p30 and 720p30?
6M 720p30 and 10M 1080p30 are general, but as I have mentioned, every person has different criteria for video quality, you can adjust accordingly.
