I’m having difficulty getting a device tree to work for a custom carrier board. The pin mapping is below. I’ve read the adaptation guide but there are a few things that are not clear to me there.
The USB lane mapping chart uses "0", "1" etc. differently between TX1 pins and the "Use Case" rows.
The "lane-map" is not clearly documented (at least not in this doc).
Any help is appreciated.
Pin Jetson TX1 Name Tegra X1 Name Physical Port
B43 USB2_D- USB3_DN USB 2 Port
B42 USB2_D+ USB3_DP
B40 USB0_D- USB0_DN USB 3 Port 0
B39 USB0_D+ USB0_DP
F44 USB_SS0_RX- PEX_RX5N
F43 USB_SS0_RX+ PEX_RX5P
C44 USB_SS0_TX- PEX_TX5N
C43 USB_SS0_TX+ PEX_TX5P
A39 USB1_D- USB2_DN USB 3 Port 1
A38 USB1_D+ USB2_DP
G43 USB_SS1_RX- PEX_RX3N
G42 USB_SS1_RX+ PEX_RX3P
D43 USB_SS1_TX- PEX_TX3N
D42 USB_SS1_TX+ PEX_TX3P
C49 PEX0_RST# PEX_L0_RST_N Ethernet Chip (82574L)
A45 PEX0_REFCLK- PEX_CLK1N
A44 PEX0_REFCLK+ PEX_CLK1P
H45 PEX0_RX- PEX_RX4N
H44 PEX0_RX+ PEX_RX4P
E45 PEX0_TX- PEX_TX4N
E44 PEX0_TX+ PEX_TX4P
The USB lane mapping chart uses “0”, “1” etc. differently between TX1 pins and the “Use Case” rows.
Could you point out where is the “USB lane mapping chart” and the “Use Case” rows?
I’m referring to the table in the “USB lane mapping” section of the “PLATFORM ADAPTATION AND
BRING-UP GUIDE”. This document is included in the driver package documents. The same table is in the OEM product design guide (table 12 in that document).
The information you provided seems incorrect.
The information in the table I provided was copied from the OEM product design guide, table 86. The “Physical Port” column of my table is the connector on our carrier board where we are routing the TX1 pins. Everything else is from the OEM guide. This is where the confusion starts for us. Where we see USB_SS0 on pins F44/43, C44/43, it is not clear if that is “Port 0” in the table you refer to in the TRM (Lane 6) or “USB_SS0” in the OEM guide (Lane 5). Table 86 seems to clearly call those pins lane 5 (and port 0).
To clarify, the Platform Adaptation Guide is in the L4T R24.2 Documentation package at http://developer.nvidia.com/embedded/dlc/l4t-documentation-24-2. Within that download, you will find the PDF, document DA_07839-001_01, under the “baggage” directory.
One fundamental question is how to modify the device tree for use-case 4 as defined there. The example given calls out a value for the lane-map of 0x11 however also shows it as 0x12 in the pcie_controller section.
Using 0x11 in both places caused the system to not boot. Changing it to 0x11 in the xusb section and 0x21 in the pcie-controller section (as stated in the guide) was the only way to make it work.
What is the distinction between the two lane-map values?
