I want to confirm display support for Tx1 module. And is it different support with the Devkit?
Confused by the question, the Dev Kit uses the module so they would support the same displays. The Dev Kit is HDMI only; I suppose whatever carrier board you use might have different display interfaces than the Dev Kit, maybe a DP interface could be wired up but it doesn’t look like anyone has tried to make a carrier board with one.
The docs would have more info: Jetson Download Center | NVIDIA Developer
