I have tried to have L4T-R28.2-DP rootfs on a SATA SSD in order to have more storage.
I have used a Kingston SUV400S SSD, that was recognized and working fine with R28.2, and cloned an image of R28.2-DP APP partition to this SSD.
I’ve added an entry for it in MMC0 /boot/extlinux.conf/extlinux.conf with same kernel args, just changing root=/dev/sda1 instead of mmcblk0p1:
LABEL ssd
MENU LABEL ssd kernel
LINUX /boot/Image
APPEND root=/dev/sda1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegra_fbmem2=0x140000@0x969e9000 lut_mem2=0x2008@0x969e6000 tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.1.1 androidboot.serialno=0334916010240 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1 root=/dev/sda1 rw rootwait rootfstype=ext4
So the system boots on MMC0 until u-boot, that finds extlinux.conf and loads the kernel image from MMC0 /boot, and then runs it with args for rootfs on /dev/sda1.
This works fine, I can see my rootfs having 64GB and mmc0 is just seen as an SD Card (which is convenient for editing extlinux.conf):
df -H -T
Filesystem Type Size Used Avail Use% Mounted on
/dev/root ext4 68G 13G 52G 19% /
devtmpfs devtmpfs 8.2G 0 8.2G 0% /dev
tmpfs tmpfs 8.3G 30M 8.3G 1% /dev/shm
tmpfs tmpfs 8.3G 15M 8.3G 1% /run
tmpfs tmpfs 5.3M 4.1k 5.3M 1% /run/lock
tmpfs tmpfs 8.3G 0 8.3G 0% /sys/fs/cgroup
tmpfs tmpfs 824M 50k 824M 1% /run/user/1001
/dev/mmcblk0p1 ext4 30G 13G 16G 43% /media/nvidia/1797fc2d-e18b-4fa5-b512-7fd7287bdcaf
But where it gets wrong is that when no monitor is plugged in HDMI, it fails to boot.
I have seen in some cases that plugging the monitor 40s after boot, it was booting a few minutes later.
In my case, having a USB hub (powered by Jetson) to be plugged could allow the system to boot only if I have only keyboard and mouse. Having my CM108 USB sound card or a USB drive make it failing to boot, even after plugging the monitor…I have to say that after 3 minutes I loosed hope and tried something else.
I’ve tried to look with serial console. Without monitor, the boot process stalls at 2 points, and then runs into faults such as:
[ 2.655543] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 12.699002] random: nonblocking pool is initialized
[ 21.486911] INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 21.492582] 3-...: (1 GPs behind) idle=28f/140000000000000/0 softirq=15/16 fqs=5251
[ 21.500406] (detected by 0, t=5252 jiffies, g=-287, c=-288, q=8)
[ 21.506507] Task dump for CPU 3:
[ 21.509732] kworker/u12:0 R running task 0 6 2 0x00000002
[ 21.516803] Workqueue: events_unbound async_run_entry_fn
[ 21.522121] Call trace:
[ 21.524569] [<ffffffc0000865b8>] __switch_to+0xa4/0xb0
[ 21.529706] [<ffffffc0012a3030>] init_mm+0x0/0x310
[ 24.074925] Watchdog detected hard LOCKUP on cpu 3
[ 24.079600] ------------[ cut here ]------------
[ 24.084455] WARNING: at ffffffc00013ed30 [verbose debug info unavailable]
[ 24.091274] Modules linked in:
[ 24.094346]
[ 24.095850] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.4.38-tegra #1
[ 24.102291] Hardware name: quill (DT)
[ 24.105977] task: ffffffc1ecec9900 ti: ffffffc1eced8000 task.ti: ffffffc1eced8000
[ 24.113474] PC is at watchdog_timer_fn+0x230/0x33c
[ 24.118270] LR is at watchdog_timer_fn+0x230/0x33c
[ 24.123083] pc : [<ffffffc00013ed30>] lr : [<ffffffc00013ed30>] pstate: 600001c5
[ 24.130489] sp : ffffffc1ecedbb20
[ 24.133809] x29: ffffffc1ecedbb20 x28: 0000000000000003
[ 24.139151] x27: ffffffc001279b30 x26: ffffffc1f5d16278
[ 24.144491] x25: ffffffc0012462d8 x24: ffffffc1ecedbe00
[ 24.149831] x23: 0000000000000000 x22: 0000000000000000
[ 24.155170] x21: ffffffc001279000 x20: ffffffc001246000
[ 24.160509] x19: ffffffc001246260 x18: ffffffc000bf5060
[ 24.165847] x17: 000000000000000e x16: ffffffc000b82a60
[ 24.171188] x15: 00000000efe4b99a x14: 0000000000000000
[ 24.176527] x13: 00000000efe4b99a x12: 0000000000000000
[ 24.181865] x11: 0000000000000400 x10: ffffffc001464e88
[ 24.187206] x9 : 000000000000017f x8 : 0000000000000002
[ 24.192548] x7 : ffffffc0012916b8 x6 : 0000000000000030
[ 24.197887] x5 : 0000000000000000 x4 : 0000000000000000
[ 24.203225] x3 : 0000000000000000 x2 : 0000000000010001
[ 24.208565] x1 : ffffffc1eced8000 x0 : 0000000000000026
[ 24.213904]
[ 24.215949] ---[ end trace 71cc46c427a3dce3 ]---
[ 24.220569] Call trace:
[ 24.223026] [<ffffffc00013ed30>] watchdog_timer_fn+0x230/0x33c
[ 24.228868] [<ffffffc000107c7c>] __hrtimer_run_queues+0x140/0x350
[ 24.234965] [<ffffffc0001086dc>] hrtimer_interrupt+0x9c/0x1e0
[ 24.240717] [<ffffffc0009315dc>] tegra186_timer_isr+0x24/0x30
[ 24.246468] [<ffffffc0000f5568>] handle_irq_event_percpu+0x84/0x290
[ 24.252737] [<ffffffc0000f57b8>] handle_irq_event+0x44/0x74
[ 24.258316] [<ffffffc0000f8ac0>] handle_fasteoi_irq+0xb4/0x188
[ 24.264153] [<ffffffc0000f4b88>] generic_handle_irq+0x24/0x38
[ 24.269902] [<ffffffc0000f4e90>] __handle_domain_irq+0x60/0xb4
[ 24.275739] [<ffffffc0000815dc>] gic_handle_irq+0x5c/0xb4
[ 24.281141] [<ffffffc000084740>] el1_irq+0x80/0xf8
[ 24.285938] [<ffffffc0000e82f4>] default_idle_call+0x1c/0x2c
[ 24.291600] [<ffffffc0000e8510>] cpu_startup_entry+0x1bc/0x340
[ 24.297437] [<ffffffc00008ede8>] secondary_start_kernel+0x12c/0x164
[ 24.303706] [<000000008008192c>] 0x8008192c
This turns into various faults, but once I’ve seen the system detecting a CPU not responding and rebooted. Usually with serial console it fails to reboot after monitor has been plugged in.
Not sure about that, but it seems that not having the serial console and no USB device, it reboots easily and the system can then successfully boot if a monitor has been plugged before it reboots.
Looking at kernel logs when it succeeds to boot after late HDMI plug in, I feel there is some race condition in linux boot depending on what devices are connected.
I have also seen something really weird. The Denver cores were detected as type 6, but version 0 instead of 2:
[ 0.480062] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 2.613504] console [ttyS0] enabled
[ 2.615449] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.615716] Console: switching to colour frame buffer device 80x30
[ 2.616546] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.616781] serial-tegra 3130000.serial: RX in PIO mode
[ 2.617682] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.644024] brd: module loaded
[ 2.648384] loop: module loaded
[ 2.648648] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.648652] nct1008_nct72 7-004c: starting parse dt
[ 2.648739] nct1008_nct72 7-004c: success parsing dt
[ 2.648869] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.708748] tegradc 15210000.nvdisplay: fb registered
[ 2.715216] PD DISP0 index2 UP
[ 2.723341] PD DISP1 index3 UP
[ 2.723390] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.734886] PD DISP2 index4 UP
[ 2.748294] Parent Clock set for DC plld2
[ 2.749677] tmp451: Enabled overheat logging at 104.00C
[ 2.749778] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.752006] THERMAL EST: found 3 subdevs
[ 2.752010] THERMAL EST num_resources: 0
[ 2.752012] [THERMAL EST subdev 0]
[ 2.752016] [THERMAL EST subdev 1]
[ 2.752019] [THERMAL EST subdev 2]
[ 2.752236] thermal thermal_zone8: Registering thermal zone thermal_zone8 for type thermal-fan-est
[ 2.752237] THERMAL EST: thz register success.
[ 2.752314] THERMAL EST: end of probe, return err: 0
[ 2.752347] tegra_profiler: Branch: Dev
[ 2.752348] tegra_profiler: Version: 1.112
[ 2.752349] tegra_profiler: Samples version: 39
[ 2.752351] tegra_profiler: IO version: 22
[ 2.752354] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.752357] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.752359] armv8_pmu: imp: 0x4e, idcode: 0x1
<b> [ 2.752360] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0</b>
[ 2.752362] armv8_pmu: imp: 0x4e, idcode: 0x1
<b> [ 2.752364] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0</b>
[ 2.752366] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.752368] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.752369] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.752371] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.752373] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.752375] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.752495] tegra_profiler: auth: init
[ 2.755279] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.755285] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.755925] scsi host0: tegra_ahci
[ 2.756155] scsi host1: tegra_ahci
[ 2.756267] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 2.756269] ata2: DUMMY
[ 2.757049] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.757416] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.757746] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.758373] tun: Universal TUN/TAP device driver, 1.6
[ 2.758375] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.758513] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.758515] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.758542] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.758543] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.759365] PPP generic driver version 2.4.2
[ 2.759462] PPP BSD Compression module registered
[ 2.759467] PPP Deflate Compression module registered
[ 2.759481] PPP MPPE Compression module registered
[ 2.759489] NET: Registered protocol family 24
[ 2.759530] usbcore: registered new interface driver r8152
[ 2.759557] usbcore: registered new interface driver asix
[ 2.759582] usbcore: registered new interface driver ax88179_178a
[ 2.759603] usbcore: registered new interface driver cdc_ether
[ 2.759634] usbcore: registered new interface driver smsc75xx
[ 2.759655] usbcore: registered new interface driver net1080
[ 2.759676] usbcore: registered new interface driver cdc_subset
[ 2.759697] usbcore: registered new interface driver zaurus
[ 2.759732] usbcore: registered new interface driver cdc_ncm
[ 2.759899] Wake76 for irq=199
[ 2.759900] Wake77 for irq=199
[ 2.759901] Wake78 for irq=199
[ 2.759902] Wake79 for irq=199
[ 2.759903] Wake80 for irq=199
[ 2.759904] Wake81 for irq=199
[ 2.759905] Wake82 for irq=199
[ 2.759952] tegra-xotg xotg: usb2 phy is not available yet
[ 2.760385] usbcore: registered new interface driver usb-storage
[ 2.760438] usbcore: registered new interface driver usbserial
[ 2.760461] usbcore: registered new interface driver cp210x
[ 2.760477] usbserial: USB Serial support registered for cp210x
[ 2.760497] usbcore: registered new interface driver ftdi_sio
[ 2.760511] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.760530] usbcore: registered new interface driver option
[ 2.760545] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.760564] usbcore: registered new interface driver pl2303
[ 2.760577] usbserial: USB Serial support registered for pl2303
[ 2.760771] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.762784] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b <s>xx xx xx</s>
[ 2.763285] libphy: dwc_phy: probed
[ 2.763737] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.828148] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.892656] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.894899] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.894912] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.895066] i2c /dev entries driver
[ 2.895820] [OV5693]: probing v4l2 sensor.
[ 3.246977] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 3.247219] ata1.00: ATA-11: KINGSTON SUV400S37120G, 0C3FD6SD, max UDMA/133
[ 3.247223] ata1.00: 234441648 sectors, multi 1: LBA48 NCQ (depth 31/32)
[ 3.247511] ata1.00: configured for UDMA/133
[ 3.280101] edid invalid
[ 3.332162] edid invalid
[ 3.335517] edid invalid
[ 3.338822] tegradc 15210000.nvdisplay: hdmi: pclk:50349K, set prod-setting:prod_c_54M
[ 3.365959] scsi 0:0:0:0: Direct-Access ATA KINGSTON SUV400S D6SD PQ: 0 ANSI: 5
[ 3.376979] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
[ 3.386084] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 3.395292] sd 0:0:0:0: [sda] Write Protect is off
[ 3.400891] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.400965] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.424167] sda: sda1 sda2 sda3
[ 3.429378] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.479285] tegradc 15210000.nvdisplay: blank - normal
[ 3.482551] tegradc 15210000.nvdisplay: blank - powerdown
[ 3.541046] PD DISP2 index4 DOWN
[ 3.542157] PD DISP1 index3 DOWN
[ 3.542840] PD DISP0 index2 DOWN
[ 3.557346] tegradc 15210000.nvdisplay: unblank
[ 3.557410] PD DISP0 index2 UP
[ 3.563294] PD DISP1 index3 UP
[ 3.563848] PD DISP2 index4 UP
[ 3.579350] Parent Clock set for DC plld2
[ 3.582814] tegradc 15210000.nvdisplay: hdmi: pclk:27027K, set prod-setting:prod_c_54M
[ 3.594397] random: nonblocking pool is initialized
…maybe some microcode failed to load.
Any idea of what’s going wrong ?
Of course, it works fine without monitor from MMC0 and this setup is not officially supported, but I think it is easy to reproduce if NVIDIA wants to investigate.
