Hi thank’s AastaLLL,
To solve this pb the entire procedure:
a) first use gst-launch-1.0 to determine the index and other parameters (here index v4l camera is 0)
$ gst-launch-1.0 v4l2src device=/dev/video0 ! videoconvert ! xvimagesink
for find others informations install:
$ install sudo apt install qv4l2
Test the parameters with gst-launch before the modification (be sur to connect it to the right device…)…
$ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw, width={1280}, height={800}, format={YUY2} ! xvimagesink -e
When its ok, go to and edit as sudo
$/usr/share/visionworks/sources/nvxio/src/NVX/FrameSource/GStreamer/GStreamerCameraFrameSourceImpl.cpp
b) at line 143 (for gst-launch1.0) modify like this (not very proper…) with using the qv4l2 reading parameters (or as you want) in this case this is a HP USB cam:
$ //~ stream << “video/x-raw, format=(string){YUY2}, width=[1,” << configuration.frameWidth <<strong text
$ //~ “], height=[1,” << configuration.frameHeight << “], framerate=” << configuration.fps << “/1;”;
$ stream << "video/x-raw, format=(string){**YUY2**}, width=[1," << **1280** <<
$ "], height=[1," << **800** << "], framerate=" << **30** << "/1;";
as said upper recompile:
$ /usr/share/visionworks/sources
$ sudo make
And it’s work…
Regard’s
Laurent.
