So far my IMX415 driver has loaded successfully, but when I try to execute
v4l2-ctl --set-fmt-video=pixelformat=RG10 --stream-mmap --stream-count=10
I get an error with the following message:
tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 84.464187] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 84.677833] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 84.684276] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 84.694013] nvcsi 150c0000.nvcsi: csi4_stream_check_status (4) ERROR_STATUS2VI_VC0 = 0x00000002
[ 84.702767] nvcsi 150c0000.nvcsi: csi4_stream_check_status (4) INTR_STATUS 0x00010002
[ 84.710611] nvcsi 150c0000.nvcsi: csi4_stream_check_status (4) ERR_INTR_STATUS 0x00010002
[ 84.921816] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 84.928401] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 84.938204] nvcsi 150c0000.nvcsi: csi4_stream_check_status (4) ERROR_STATUS2VI_VC0 = 0x00000002
[ 84.947031] nvcsi 150c0000.nvcsi: csi4_stream_check_status (4) INTR_STATUS 0x00010000
[ 84.954973] nvcsi 150c0000.nvcsi: csi4_stream_check_status (4) ERR_INTR_STATUS 0x00010000
[ 85.165826] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 85.172214] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 85.182086] nvcsi 150c0000.nvcsi: csi4_stream_check_status (4) ERROR_STATUS2VI_VC0 = 0x00000002
[ 85.190871] nvcsi 150c0000.nvcsi: csi4_stream_check_status (4) ERROR_STATUS2VI_VC2 = 0x0000000a
[ 85.190875] nvcsi 150c0000.nvcsi: csi4_stream_check_status (4) ERROR_STATUS2VI_VC2 = 0x00000008
[ 85.190878] nvcsi 150c0000.nvcsi: csi4_stream_check_status (4) INTR_STATUS 0x00018a00
[ 85.190882] nvcsi 150c0000.nvcsi: csi4_stream_check_status (4) ERR_INTR_STATUS 0x00018a00
kernel log:
# tracer: nop
# entries-in-buffer/entries-written: 372/372 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/5:1-773 [005] .... 73.277788: rtos_queue_peek_from_isr_failed: tstamp:2528758616 queue:0x0b4b4940
kworker/5:1-773 [005] .... 73.389795: rtos_queue_peek_from_isr_failed: tstamp:2533758598 queue:0x0b4b4940
kworker/5:1-773 [005] .... 73.557796: rtos_queue_peek_from_isr_failed: tstamp:2538758595 queue:0x0b4b4940
kworker/5:1-773 [005] .... 73.725775: rtos_queue_peek_from_isr_failed: tstamp:2543758586 queue:0x0b4b4940
kworker/5:1-773 [005] .... 73.893799: rtos_queue_peek_from_isr_failed: tstamp:2548758580 queue:0x0b4b4940
kworker/5:1-773 [005] .... 74.065836: rtos_queue_peek_from_isr_failed: tstamp:2553758570 queue:0x0b4b4940
kworker/5:2-1163 [005] .... 74.233792: rtos_queue_peek_from_isr_failed: tstamp:2558758566 queue:0x0b4b4940
kworker/5:1-773 [005] .... 74.401810: rtos_queue_peek_from_isr_failed: tstamp:2563758557 queue:0x0b4b4940
kworker/5:2-1163 [005] .... 74.513778: rtos_queue_peek_from_isr_failed: tstamp:2568758551 queue:0x0b4b4940
kworker/5:2-1163 [005] .... 74.681786: rtos_queue_peek_from_isr_failed: tstamp:2573758545 queue:0x0b4b4940
kworker/5:2-1163 [005] .... 74.849799: rtos_queue_peek_from_isr_failed: tstamp:2578758539 queue:0x0b4b4940
kworker/5:2-1163 [005] .... 75.017785: rtos_queue_peek_from_isr_failed: tstamp:2583758529 queue:0x0b4b4940
kworker/5:2-1163 [005] .... 75.185790: rtos_queue_peek_from_isr_failed: tstamp:2588758523 queue:0x0b4b4940
kworker/5:2-1163 [005] .... 75.353786: rtos_queue_peek_from_isr_failed: tstamp:2593758516 queue:0x0b4b4940
kworker/5:2-1163 [005] .... 75.521793: rtos_queue_peek_from_isr_failed: tstamp:2598758511 queue:0x0b4b4940
kworker/5:2-1163 [005] .... 75.633813: rtos_queue_peek_from_isr_failed: tstamp:2603758505 queue:0x0b4b4940
kworker/5:2-1163 [005] .... 75.801804: rtos_queue_peek_from_isr_failed: tstamp:2608758499 queue:0x0b4b4940
kworker/5:2-1163 [005] .... 75.969804: rtos_queue_peek_from_isr_failed: tstamp:2613758489 queue:0x0b4b4940
kworker/5:2-1163 [005] .... 76.137798: rtos_queue_peek_from_isr_failed: tstamp:2618758482 queue:0x0b4b4940
kworker/5:2-1163 [005] .... 76.305814: rtos_queue_peek_from_isr_failed: tstamp:2623758478 queue:0x0b4b4940
kworker/5:2-1163 [005] .... 76.473800: rtos_queue_peek_from_isr_failed: tstamp:2628758470 queue:0x0b4b4940
kworker/5:1-773 [005] .... 76.641792: rtos_queue_peek_from_isr_failed: tstamp:2633758464 queue:0x0b4b4940
kworker/5:1-773 [005] .... 76.753777: rtos_queue_peek_from_isr_failed: tstamp:2638758456 queue:0x0b4b4940
kworker/5:1-773 [005] .... 76.925792: rtos_queue_peek_from_isr_failed: tstamp:2643758450 queue:0x0b4b4940
kworker/5:1-773 [005] .... 77.093801: rtos_queue_peek_from_isr_failed: tstamp:2648758441 queue:0x0b4b4940
kworker/5:1-773 [005] .... 77.261799: rtos_queue_peek_from_isr_failed: tstamp:2653758436 queue:0x0b4b4940
kworker/5:1-773 [005] .... 77.429811: rtos_queue_peek_from_isr_failed: tstamp:2658758429 queue:0x0b4b4940
kworker/5:1-773 [005] .... 77.601799: rtos_queue_peek_from_isr_failed: tstamp:2663758423 queue:0x0b4b4940
kworker/5:1-773 [005] .... 77.713827: rtos_queue_peek_from_isr_failed: tstamp:2668758415 queue:0x0b4b4940
kworker/5:2-1163 [005] .... 77.881797: rtos_queue_peek_from_isr_failed: tstamp:2673758409 queue:0x0b4b4940
kworker/5:2-1163 [005] .... 77.937801: rtos_queue_peek_from_isr_failed: tstamp:2675121058 queue:0x0b4b4940
v4l2-ctl-11997 [004] .... 84.186073: tegra_channel_open: vi-output, imx415 9-001a
v4l2-ctl-11997 [004] .... 84.203721: tegra_channel_set_power: imx415 9-001a : 0x1
v4l2-ctl-11997 [004] .... 84.203730: camera_common_s_power: status : 0x1
v4l2-ctl-11997 [004] .... 84.214090: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
v4l2-ctl-11997 [004] .... 84.214095: csi_s_power: enable : 0x1
v4l2-ctl-11997 [004] .... 84.216447: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 20
vi-output, imx4-12001 [005] .... 84.216554: tegra_channel_set_stream: enable : 0x1
vi-output, imx4-12001 [005] .... 84.217513: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x1
vi-output, imx4-12001 [005] .... 84.217515: csi_s_stream: enable : 0x1
vi-output, imx4-12001 [005] .... 84.217554: tegra_channel_set_stream: imx415 9-001a : 0x1
kworker/5:1-773 [005] .... 84.229797: rtos_queue_peek_from_isr_failed: tstamp:2872192065 queue:0x0b4b4940
kworker/5:1-773 [005] .... 84.229801: rtcpu_start: tstamp:2872192887
kworker/5:1-773 [005] .... 84.229803: rtos_queue_send_from_isr_failed: tstamp:2872199403 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.229804: rtos_queue_send_from_isr_failed: tstamp:2872199509 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 84.229805: rtos_queue_send_from_isr_failed: tstamp:2872199616 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 84.229805: rtos_queue_send_from_isr_failed: tstamp:2872199723 queue:0x0b4af718
kworker/5:1-773 [005] .... 84.229806: rtos_queue_send_from_isr_failed: tstamp:2872199827 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 84.229807: rtos_queue_send_from_isr_failed: tstamp:2872199931 queue:0x0b4b1298
kworker/5:1-773 [005] .... 84.229807: rtos_queue_send_from_isr_failed: tstamp:2872200036 queue:0x0b4b2058
kworker/5:1-773 [005] .... 84.229809: rtos_queue_send_failed: tstamp:2872200479 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.229809: rtos_queue_send_from_isr_failed: tstamp:2872201993 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.229810: rtos_queue_send_from_isr_failed: tstamp:2872202104 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 84.229810: rtos_queue_send_from_isr_failed: tstamp:2872202209 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 84.229811: rtos_queue_send_from_isr_failed: tstamp:2872202317 queue:0x0b4af718
kworker/5:1-773 [005] .... 84.229812: rtos_queue_send_from_isr_failed: tstamp:2872202422 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 84.229812: rtos_queue_send_from_isr_failed: tstamp:2872202527 queue:0x0b4b1298
kworker/5:1-773 [005] .... 84.229813: rtos_queue_send_from_isr_failed: tstamp:2872202632 queue:0x0b4b2058
kworker/5:1-773 [005] .... 84.229813: rtos_queue_send_failed: tstamp:2872203567 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.397814: rtos_queue_peek_from_isr_failed: tstamp:2877192413 queue:0x0b4b4940
vi-output, imx4-12001 [004] .... 84.474225: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 20
vi-output, imx4-12001 [004] .... 84.474259: tegra_channel_capture_frame: sof:-549620687220.-271498066944
kworker/5:1-773 [005] .... 84.509804: rtos_queue_send_from_isr_failed: tstamp:2880247937 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.509807: rtos_queue_send_from_isr_failed: tstamp:2880248045 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 84.509807: rtos_queue_send_from_isr_failed: tstamp:2880248152 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 84.509808: rtos_queue_send_from_isr_failed: tstamp:2880248260 queue:0x0b4af718
kworker/5:1-773 [005] .... 84.509809: rtos_queue_send_from_isr_failed: tstamp:2880248364 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 84.509809: rtos_queue_send_from_isr_failed: tstamp:2880248469 queue:0x0b4b1298
kworker/5:1-773 [005] .... 84.509810: rtos_queue_send_from_isr_failed: tstamp:2880248574 queue:0x0b4b2058
kworker/5:1-773 [005] .... 84.509811: rtos_queue_send_failed: tstamp:2880249161 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.509812: rtos_queue_send_from_isr_failed: tstamp:2880250763 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.509812: rtos_queue_send_from_isr_failed: tstamp:2880250869 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 84.509813: rtos_queue_send_from_isr_failed: tstamp:2880250975 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 84.509814: rtos_queue_send_from_isr_failed: tstamp:2880251083 queue:0x0b4af718
kworker/5:1-773 [005] .... 84.509814: rtos_queue_send_from_isr_failed: tstamp:2880251198 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 84.509815: rtos_queue_send_from_isr_failed: tstamp:2880251302 queue:0x0b4b1298
kworker/5:1-773 [005] .... 84.509815: rtos_queue_send_from_isr_failed: tstamp:2880251416 queue:0x0b4b2058
kworker/5:1-773 [005] .... 84.509816: rtos_queue_send_failed: tstamp:2880251836 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.509817: rtos_queue_send_from_isr_failed: tstamp:2880255413 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.509817: rtos_queue_send_from_isr_failed: tstamp:2880255519 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 84.509818: rtos_queue_send_from_isr_failed: tstamp:2880255625 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 84.509818: rtos_queue_send_from_isr_failed: tstamp:2880255733 queue:0x0b4af718
kworker/5:1-773 [005] .... 84.509819: rtos_queue_send_from_isr_failed: tstamp:2880255838 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 84.509820: rtos_queue_send_from_isr_failed: tstamp:2880255943 queue:0x0b4b1298
kworker/5:1-773 [005] .... 84.509820: rtos_queue_send_from_isr_failed: tstamp:2880256047 queue:0x0b4b2058
kworker/5:1-773 [005] .... 84.509821: rtos_queue_send_failed: tstamp:2880256475 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.509821: rtos_queue_send_from_isr_failed: tstamp:2880257592 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.509822: rtos_queue_send_from_isr_failed: tstamp:2880257699 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 84.509823: rtos_queue_send_from_isr_failed: tstamp:2880257805 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 84.509823: rtos_queue_send_from_isr_failed: tstamp:2880257911 queue:0x0b4af718
kworker/5:1-773 [005] .... 84.509824: rtos_queue_send_from_isr_failed: tstamp:2880258017 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 84.509825: rtos_queue_send_from_isr_failed: tstamp:2880258121 queue:0x0b4b1298
kworker/5:1-773 [005] .... 84.509825: rtos_queue_send_from_isr_failed: tstamp:2880258226 queue:0x0b4b2058
kworker/5:1-773 [005] .... 84.509826: rtos_queue_send_failed: tstamp:2880259151 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.565796: rtos_queue_peek_from_isr_failed: tstamp:2882192407 queue:0x0b4b4940
vi-output, imx4-12001 [004] .... 84.718854: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 20
vi-output, imx4-12001 [004] .... 84.718888: tegra_channel_capture_frame: sof:-549620687220.-271498066944
kworker/5:1-773 [005] .... 84.733804: rtos_queue_send_from_isr_failed: tstamp:2887122622 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.733807: rtos_queue_send_from_isr_failed: tstamp:2887122729 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 84.733808: rtos_queue_send_from_isr_failed: tstamp:2887122837 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 84.733809: rtos_queue_send_from_isr_failed: tstamp:2887122944 queue:0x0b4af718
kworker/5:1-773 [005] .... 84.733810: rtos_queue_send_from_isr_failed: tstamp:2887123048 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 84.733810: rtos_queue_send_from_isr_failed: tstamp:2887123152 queue:0x0b4b1298
kworker/5:1-773 [005] .... 84.733811: rtos_queue_send_from_isr_failed: tstamp:2887123257 queue:0x0b4b2058
kworker/5:1-773 [005] .... 84.733812: rtos_queue_send_failed: tstamp:2887123853 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.733813: rtos_queue_send_from_isr_failed: tstamp:2887125320 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.733814: rtos_queue_send_from_isr_failed: tstamp:2887125427 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 84.733814: rtos_queue_send_from_isr_failed: tstamp:2887125534 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 84.733815: rtos_queue_send_from_isr_failed: tstamp:2887125641 queue:0x0b4af718
kworker/5:1-773 [005] .... 84.733815: rtos_queue_send_from_isr_failed: tstamp:2887125748 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 84.733816: rtos_queue_send_from_isr_failed: tstamp:2887125854 queue:0x0b4b1298
kworker/5:1-773 [005] .... 84.733817: rtos_queue_send_from_isr_failed: tstamp:2887125959 queue:0x0b4b2058
kworker/5:1-773 [005] .... 84.733817: rtos_queue_send_failed: tstamp:2887126390 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.733818: rtos_queue_peek_from_isr_failed: tstamp:2887192400 queue:0x0b4b4940
kworker/5:1-773 [005] .... 84.733819: rtos_queue_send_from_isr_failed: tstamp:2887648949 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.733819: rtos_queue_send_from_isr_failed: tstamp:2887649057 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 84.733820: rtos_queue_send_from_isr_failed: tstamp:2887649167 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 84.733821: rtos_queue_send_from_isr_failed: tstamp:2887649275 queue:0x0b4af718
kworker/5:1-773 [005] .... 84.733821: rtos_queue_send_from_isr_failed: tstamp:2887649378 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 84.733822: rtos_queue_send_from_isr_failed: tstamp:2887649482 queue:0x0b4b1298
kworker/5:1-773 [005] .... 84.733822: rtos_queue_send_from_isr_failed: tstamp:2887649586 queue:0x0b4b2058
kworker/5:1-773 [005] .... 84.733823: rtos_queue_send_failed: tstamp:2887650018 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.733823: rtos_queue_send_from_isr_failed: tstamp:2887651390 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.733824: rtos_queue_send_from_isr_failed: tstamp:2887651496 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 84.733825: rtos_queue_send_from_isr_failed: tstamp:2887651601 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 84.733825: rtos_queue_send_from_isr_failed: tstamp:2887651709 queue:0x0b4af718
kworker/5:1-773 [005] .... 84.733826: rtos_queue_send_from_isr_failed: tstamp:2887651815 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 84.733827: rtos_queue_send_from_isr_failed: tstamp:2887651920 queue:0x0b4b1298
kworker/5:1-773 [005] .... 84.733827: rtos_queue_send_from_isr_failed: tstamp:2887652025 queue:0x0b4b2058
kworker/5:1-773 [005] .... 84.733828: rtos_queue_send_failed: tstamp:2887652952 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.901793: rtos_queue_peek_from_isr_failed: tstamp:2892192397 queue:0x0b4b4940
kworker/5:1-773 [005] .... 84.957786: rtos_queue_send_from_isr_failed: tstamp:2894752414 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.957789: rtos_queue_send_from_isr_failed: tstamp:2894752523 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 84.957790: rtos_queue_send_from_isr_failed: tstamp:2894752630 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 84.957790: rtos_queue_send_from_isr_failed: tstamp:2894752743 queue:0x0b4af718
kworker/5:1-773 [005] .... 84.957791: rtos_queue_send_from_isr_failed: tstamp:2894752848 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 84.957792: rtos_queue_send_from_isr_failed: tstamp:2894752952 queue:0x0b4b1298
kworker/5:1-773 [005] .... 84.957792: rtos_queue_send_from_isr_failed: tstamp:2894753057 queue:0x0b4b2058
kworker/5:1-773 [005] .... 84.957794: rtos_queue_send_failed: tstamp:2894753644 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.957794: rtos_queue_send_from_isr_failed: tstamp:2894755670 queue:0x0b4a7698
kworker/5:1-773 [005] .... 84.957795: rtos_queue_send_from_isr_failed: tstamp:2894755788 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 84.957796: rtos_queue_send_from_isr_failed: tstamp:2894755894 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 84.957796: rtos_queue_send_from_isr_failed: tstamp:2894756011 queue:0x0b4af718
kworker/5:1-773 [005] .... 84.957797: rtos_queue_send_from_isr_failed: tstamp:2894756116 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 84.957797: rtos_queue_send_from_isr_failed: tstamp:2894756221 queue:0x0b4b1298
kworker/5:1-773 [005] .... 84.957798: rtos_queue_send_from_isr_failed: tstamp:2894756326 queue:0x0b4b2058
kworker/5:1-773 [005] .... 84.957798: rtos_queue_send_failed: tstamp:2894756755 queue:0x0b4a7698
vi-output, imx4-12001 [000] .... 84.963476: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 20
vi-output, imx4-12001 [000] .... 84.963509: tegra_channel_capture_frame: sof:-549620687220.-271498066944
kworker/5:1-773 [005] .... 85.013787: rtos_queue_send_from_isr_failed: tstamp:2895543428 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.013790: rtos_queue_send_from_isr_failed: tstamp:2895543536 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 85.013790: rtos_queue_send_from_isr_failed: tstamp:2895543642 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 85.013791: rtos_queue_send_from_isr_failed: tstamp:2895543750 queue:0x0b4af718
kworker/5:1-773 [005] .... 85.013792: rtos_queue_send_from_isr_failed: tstamp:2895543855 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 85.013792: rtos_queue_send_from_isr_failed: tstamp:2895543960 queue:0x0b4b1298
kworker/5:1-773 [005] .... 85.013793: rtos_queue_send_from_isr_failed: tstamp:2895544065 queue:0x0b4b2058
kworker/5:1-773 [005] .... 85.013794: rtos_queue_send_failed: tstamp:2895544523 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.013795: rtos_queue_send_from_isr_failed: tstamp:2895546487 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.013795: rtos_queue_send_from_isr_failed: tstamp:2895546593 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 85.013796: rtos_queue_send_from_isr_failed: tstamp:2895546700 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 85.013797: rtos_queue_send_from_isr_failed: tstamp:2895546809 queue:0x0b4af718
kworker/5:1-773 [005] .... 85.013797: rtos_queue_send_from_isr_failed: tstamp:2895546911 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 85.013798: rtos_queue_send_from_isr_failed: tstamp:2895547015 queue:0x0b4b1298
kworker/5:1-773 [005] .... 85.013799: rtos_queue_send_from_isr_failed: tstamp:2895547120 queue:0x0b4b2058
kworker/5:1-773 [005] .... 85.013799: rtos_queue_send_failed: tstamp:2895548052 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.069792: rtos_queue_peek_from_isr_failed: tstamp:2897192392 queue:0x0b4b4940
kworker/5:1-773 [005] .... 85.069796: rtcpu_vinotify_event: tstamp:2898849412 tag:CSIMUX_STREAM channel:0xff frame:512 vi_tstamp:2898849026 data:0x00010000
kworker/5:1-773 [005] .... 85.125777: rtcpu_vinotify_event: tstamp:2900313768 tag:CSIMUX_STREAM channel:0xff frame:768 vi_tstamp:2900313387 data:0x00010000
kworker/5:1-773 [005] .... 85.181812: rtos_queue_peek_from_isr_failed: tstamp:2902192379 queue:0x0b4b4940
vi-output, imx4-12001 [003] .... 85.208434: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 20
vi-output, imx4-12001 [003] .... 85.208473: tegra_channel_capture_frame: sof:-549620687220.-271498066944
kworker/5:1-773 [005] .... 85.237792: rtos_queue_send_from_isr_failed: tstamp:2902374338 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.237796: rtos_queue_send_from_isr_failed: tstamp:2902374448 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 85.237796: rtos_queue_send_from_isr_failed: tstamp:2902374557 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 85.237797: rtos_queue_send_from_isr_failed: tstamp:2902374665 queue:0x0b4af718
kworker/5:1-773 [005] .... 85.237798: rtos_queue_send_from_isr_failed: tstamp:2902374768 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 85.237798: rtos_queue_send_from_isr_failed: tstamp:2902374873 queue:0x0b4b1298
kworker/5:1-773 [005] .... 85.237799: rtos_queue_send_from_isr_failed: tstamp:2902374978 queue:0x0b4b2058
kworker/5:1-773 [005] .... 85.237800: rtos_queue_send_failed: tstamp:2902375603 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.237801: rtos_queue_send_from_isr_failed: tstamp:2902377235 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.237802: rtos_queue_send_from_isr_failed: tstamp:2902377341 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 85.237802: rtos_queue_send_from_isr_failed: tstamp:2902377447 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 85.237803: rtos_queue_send_from_isr_failed: tstamp:2902377556 queue:0x0b4af718
kworker/5:1-773 [005] .... 85.237803: rtos_queue_send_from_isr_failed: tstamp:2902377661 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 85.237804: rtos_queue_send_from_isr_failed: tstamp:2902377766 queue:0x0b4b1298
kworker/5:1-773 [005] .... 85.237805: rtos_queue_send_from_isr_failed: tstamp:2902377870 queue:0x0b4b2058
kworker/5:1-773 [005] .... 85.237805: rtos_queue_send_failed: tstamp:2902378310 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.237806: rtos_queue_send_from_isr_failed: tstamp:2902681455 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.237806: rtos_queue_send_from_isr_failed: tstamp:2902681561 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 85.237807: rtos_queue_send_from_isr_failed: tstamp:2902681667 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 85.237808: rtos_queue_send_from_isr_failed: tstamp:2902681775 queue:0x0b4af718
kworker/5:1-773 [005] .... 85.237808: rtos_queue_send_from_isr_failed: tstamp:2902681880 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 85.237809: rtos_queue_send_from_isr_failed: tstamp:2902681985 queue:0x0b4b1298
kworker/5:1-773 [005] .... 85.237809: rtos_queue_send_from_isr_failed: tstamp:2902682090 queue:0x0b4b2058
kworker/5:1-773 [005] .... 85.237810: rtos_queue_send_failed: tstamp:2902682531 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.237811: rtos_queue_send_from_isr_failed: tstamp:2902936350 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.237811: rtos_queue_send_from_isr_failed: tstamp:2902936458 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 85.237812: rtos_queue_send_from_isr_failed: tstamp:2902936563 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 85.237812: rtos_queue_send_from_isr_failed: tstamp:2902936670 queue:0x0b4af718
kworker/5:1-773 [005] .... 85.237813: rtos_queue_send_from_isr_failed: tstamp:2902936774 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 85.237814: rtos_queue_send_from_isr_failed: tstamp:2902936879 queue:0x0b4b1298
kworker/5:1-773 [005] .... 85.237814: rtos_queue_send_from_isr_failed: tstamp:2902936984 queue:0x0b4b2058
kworker/5:1-773 [005] .... 85.237815: rtos_queue_send_failed: tstamp:2902937895 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.237816: rtcpu_vinotify_event: tstamp:2903121629 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:2903121233 data:0x00010000
kworker/5:1-773 [005] .... 85.237817: rtcpu_vinotify_event: tstamp:2903575040 tag:CSIMUX_STREAM channel:0xff frame:768 vi_tstamp:2903574653 data:0x00010000
kworker/5:1-773 [005] .... 85.353788: rtos_queue_peek_from_isr_failed: tstamp:2907192371 queue:0x0b4b4940
kworker/5:2-1163 [005] .... 85.409791: rtcpu_vinotify_event: tstamp:2908456234 tag:CSIMUX_STREAM channel:0xff frame:256 vi_tstamp:2908455853 data:0x00010000
vi-output, imx4-12001 [003] .... 85.426155: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 20
vi-output, imx4-12001 [003] .... 85.426189: tegra_channel_capture_frame: sof:-549620687220.-271498066944
kworker/5:1-773 [005] .... 85.471657: rtos_queue_send_from_isr_failed: tstamp:2909993763 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.471660: rtos_queue_send_from_isr_failed: tstamp:2909993873 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 85.471661: rtos_queue_send_from_isr_failed: tstamp:2909993982 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 85.471662: rtos_queue_send_from_isr_failed: tstamp:2909994100 queue:0x0b4af718
kworker/5:1-773 [005] .... 85.471663: rtos_queue_send_from_isr_failed: tstamp:2909994205 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 85.471664: rtos_queue_send_from_isr_failed: tstamp:2909994310 queue:0x0b4b1298
kworker/5:1-773 [005] .... 85.471664: rtos_queue_send_from_isr_failed: tstamp:2909994415 queue:0x0b4b2058
kworker/5:1-773 [005] .... 85.471666: rtos_queue_send_failed: tstamp:2909995014 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.471667: rtos_queue_send_from_isr_failed: tstamp:2909997525 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.471668: rtos_queue_send_from_isr_failed: tstamp:2909997632 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 85.471669: rtos_queue_send_from_isr_failed: tstamp:2909997739 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 85.471670: rtos_queue_send_from_isr_failed: tstamp:2909997845 queue:0x0b4af718
kworker/5:1-773 [005] .... 85.471671: rtos_queue_send_from_isr_failed: tstamp:2909997949 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 85.471672: rtos_queue_send_from_isr_failed: tstamp:2909998054 queue:0x0b4b1298
kworker/5:1-773 [005] .... 85.471672: rtos_queue_send_from_isr_failed: tstamp:2909998159 queue:0x0b4b2058
kworker/5:1-773 [005] .... 85.471673: rtos_queue_send_failed: tstamp:2909998585 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.471674: rtos_queue_send_from_isr_failed: tstamp:2910003054 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.471675: rtos_queue_send_from_isr_failed: tstamp:2910003161 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 85.471676: rtos_queue_send_from_isr_failed: tstamp:2910003266 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 85.471677: rtos_queue_send_from_isr_failed: tstamp:2910003375 queue:0x0b4af718
kworker/5:1-773 [005] .... 85.471678: rtos_queue_send_from_isr_failed: tstamp:2910003479 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 85.471678: rtos_queue_send_from_isr_failed: tstamp:2910003584 queue:0x0b4b1298
kworker/5:1-773 [005] .... 85.471679: rtos_queue_send_from_isr_failed: tstamp:2910003688 queue:0x0b4b2058
kworker/5:1-773 [005] .... 85.471680: rtos_queue_send_failed: tstamp:2910004122 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.471681: rtos_queue_send_from_isr_failed: tstamp:2910005358 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.471682: rtos_queue_send_from_isr_failed: tstamp:2910005464 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 85.471682: rtos_queue_send_from_isr_failed: tstamp:2910005571 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 85.471683: rtos_queue_send_from_isr_failed: tstamp:2910005678 queue:0x0b4af718
kworker/5:1-773 [005] .... 85.471684: rtos_queue_send_from_isr_failed: tstamp:2910005782 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 85.471685: rtos_queue_send_from_isr_failed: tstamp:2910005886 queue:0x0b4b1298
kworker/5:1-773 [005] .... 85.471685: rtos_queue_send_from_isr_failed: tstamp:2910005991 queue:0x0b4b2058
kworker/5:1-773 [005] .... 85.471686: rtos_queue_send_failed: tstamp:2910006906 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.525800: rtos_queue_peek_from_isr_failed: tstamp:2912192365 queue:0x0b4b4940
kworker/5:1-773 [005] .... 85.637775: rtos_queue_send_from_isr_failed: tstamp:2916572431 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.637778: rtos_queue_send_from_isr_failed: tstamp:2916572539 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 85.637779: rtos_queue_send_from_isr_failed: tstamp:2916572647 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 85.637780: rtos_queue_send_from_isr_failed: tstamp:2916572754 queue:0x0b4af718
kworker/5:1-773 [005] .... 85.637780: rtos_queue_send_from_isr_failed: tstamp:2916572859 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 85.637781: rtos_queue_send_from_isr_failed: tstamp:2916572964 queue:0x0b4b1298
kworker/5:1-773 [005] .... 85.637782: rtos_queue_send_from_isr_failed: tstamp:2916573068 queue:0x0b4b2058
kworker/5:1-773 [005] .... 85.637783: rtos_queue_send_failed: tstamp:2916573665 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.693818: rtos_queue_send_from_isr_failed: tstamp:2916871002 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.693822: rtos_queue_send_from_isr_failed: tstamp:2916871111 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 85.693822: rtos_queue_send_from_isr_failed: tstamp:2916871217 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 85.693823: rtos_queue_send_from_isr_failed: tstamp:2916871326 queue:0x0b4af718
kworker/5:1-773 [005] .... 85.693824: rtos_queue_send_from_isr_failed: tstamp:2916871430 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 85.693824: rtos_queue_send_from_isr_failed: tstamp:2916871533 queue:0x0b4b1298
kworker/5:1-773 [005] .... 85.693825: rtos_queue_send_from_isr_failed: tstamp:2916871637 queue:0x0b4b2058
kworker/5:1-773 [005] .... 85.693826: rtos_queue_send_failed: tstamp:2916872077 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.693828: rtos_queue_peek_from_isr_failed: tstamp:2917192359 queue:0x0b4b4940
vi-output, imx4-12001 [003] .... 85.697193: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 20
vi-output, imx4-12001 [003] .... 85.697227: tegra_channel_capture_frame: sof:-549620687220.-271498066944
kworker/5:1-773 [005] .... 85.749802: rtos_queue_send_from_isr_failed: tstamp:2918472013 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.749805: rtos_queue_send_from_isr_failed: tstamp:2918472122 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 85.749806: rtos_queue_send_from_isr_failed: tstamp:2918472229 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 85.749806: rtos_queue_send_from_isr_failed: tstamp:2918472337 queue:0x0b4af718
kworker/5:1-773 [005] .... 85.749807: rtos_queue_send_from_isr_failed: tstamp:2918472441 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 85.749808: rtos_queue_send_from_isr_failed: tstamp:2918472544 queue:0x0b4b1298
kworker/5:1-773 [005] .... 85.749808: rtos_queue_send_from_isr_failed: tstamp:2918472653 queue:0x0b4b2058
kworker/5:1-773 [005] .... 85.749810: rtos_queue_send_failed: tstamp:2918473097 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.749810: rtos_queue_send_from_isr_failed: tstamp:2918475120 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.749811: rtos_queue_send_from_isr_failed: tstamp:2918475225 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 85.749812: rtos_queue_send_from_isr_failed: tstamp:2918475330 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 85.749812: rtos_queue_send_from_isr_failed: tstamp:2918475437 queue:0x0b4af718
kworker/5:1-773 [005] .... 85.749813: rtos_queue_send_from_isr_failed: tstamp:2918475541 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 85.749814: rtos_queue_send_from_isr_failed: tstamp:2918475645 queue:0x0b4b1298
kworker/5:1-773 [005] .... 85.749814: rtos_queue_send_from_isr_failed: tstamp:2918475750 queue:0x0b4b2058
kworker/5:1-773 [005] .... 85.749815: rtos_queue_send_failed: tstamp:2918476672 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.805777: rtcpu_vinotify_event: tstamp:2920843151 tag:CSIMUX_STREAM channel:0xff frame:256 vi_tstamp:2920842765 data:0x00010000
kworker/5:1-773 [005] .... 85.861801: rtos_queue_peek_from_isr_failed: tstamp:2922192363 queue:0x0b4b4940
v4l2-ctl-11997 [004] .... 85.867213: tegra_channel_close: vi-output, imx415 9-001a
kworker/5:1-773 [005] .... 85.917804: rtcpu_vinotify_event: tstamp:2924895004 tag:CSIMUX_STREAM channel:0xff frame:512 vi_tstamp:2924894623 data:0x00010000
kworker/5:1-773 [005] .... 85.917809: rtos_queue_send_from_isr_failed: tstamp:2925243388 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.917810: rtos_queue_send_from_isr_failed: tstamp:2925243500 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 85.917811: rtos_queue_send_from_isr_failed: tstamp:2925243609 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 85.917811: rtos_queue_send_from_isr_failed: tstamp:2925243717 queue:0x0b4af718
kworker/5:1-773 [005] .... 85.917812: rtos_queue_send_from_isr_failed: tstamp:2925243822 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 85.917813: rtos_queue_send_from_isr_failed: tstamp:2925243927 queue:0x0b4b1298
kworker/5:1-773 [005] .... 85.917813: rtos_queue_send_from_isr_failed: tstamp:2925244032 queue:0x0b4b2058
kworker/5:1-773 [005] .... 85.917815: rtos_queue_send_failed: tstamp:2925244643 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.917815: rtos_queue_send_from_isr_failed: tstamp:2925246755 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.917816: rtos_queue_send_from_isr_failed: tstamp:2925246862 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 85.917817: rtos_queue_send_from_isr_failed: tstamp:2925246968 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 85.917817: rtos_queue_send_from_isr_failed: tstamp:2925247074 queue:0x0b4af718
kworker/5:1-773 [005] .... 85.917818: rtos_queue_send_from_isr_failed: tstamp:2925247179 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 85.917818: rtos_queue_send_from_isr_failed: tstamp:2925247284 queue:0x0b4b1298
kworker/5:1-773 [005] .... 85.917819: rtos_queue_send_from_isr_failed: tstamp:2925247389 queue:0x0b4b2058
kworker/5:1-773 [005] .... 85.917820: rtos_queue_send_failed: tstamp:2925247811 queue:0x0b4a7698
vi-output, imx4-12001 [003] .... 85.964937: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 20
vi-output, imx4-12001 [003] .... 85.964971: tegra_channel_capture_frame: sof:-549620687220.-271498066944
v4l2-ctl-11997 [003] .... 85.965152: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-11997 [003] .... 85.965154: tegra_channel_set_stream: imx415 9-001a : 0x0
v4l2-ctl-11997 [004] .... 85.965447: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x0
v4l2-ctl-11997 [004] .... 85.965450: csi_s_stream: enable : 0x0
kworker/5:1-773 [005] .... 85.973816: rtos_queue_send_from_isr_failed: tstamp:2926343128 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.973819: rtos_queue_send_from_isr_failed: tstamp:2926343235 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 85.973819: rtos_queue_send_from_isr_failed: tstamp:2926343341 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 85.973820: rtos_queue_send_from_isr_failed: tstamp:2926343449 queue:0x0b4af718
kworker/5:1-773 [005] .... 85.973820: rtos_queue_send_from_isr_failed: tstamp:2926343552 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 85.973821: rtos_queue_send_from_isr_failed: tstamp:2926343657 queue:0x0b4b1298
kworker/5:1-773 [005] .... 85.973822: rtos_queue_send_from_isr_failed: tstamp:2926343762 queue:0x0b4b2058
kworker/5:1-773 [005] .... 85.973823: rtos_queue_send_failed: tstamp:2926344197 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.973824: rtos_queue_send_from_isr_failed: tstamp:2926587322 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.973824: rtos_queue_send_from_isr_failed: tstamp:2926587430 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 85.973825: rtos_queue_send_from_isr_failed: tstamp:2926587537 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 85.973826: rtos_queue_send_from_isr_failed: tstamp:2926587645 queue:0x0b4af718
kworker/5:1-773 [005] .... 85.973826: rtos_queue_send_from_isr_failed: tstamp:2926587749 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 85.973827: rtos_queue_send_from_isr_failed: tstamp:2926587863 queue:0x0b4b1298
kworker/5:1-773 [005] .... 85.973828: rtos_queue_send_from_isr_failed: tstamp:2926587969 queue:0x0b4b2058
kworker/5:1-773 [005] .... 85.973828: rtos_queue_send_failed: tstamp:2926588891 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.973829: rtos_queue_send_from_isr_failed: tstamp:2926846637 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.973829: rtos_queue_send_from_isr_failed: tstamp:2926846743 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 85.973830: rtos_queue_send_from_isr_failed: tstamp:2926846850 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 85.973831: rtos_queue_send_from_isr_failed: tstamp:2926846956 queue:0x0b4af718
kworker/5:1-773 [005] .... 85.973831: rtos_queue_send_from_isr_failed: tstamp:2926847061 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 85.973832: rtos_queue_send_from_isr_failed: tstamp:2926847166 queue:0x0b4b1298
kworker/5:1-773 [005] .... 85.973832: rtos_queue_send_from_isr_failed: tstamp:2926847271 queue:0x0b4b2058
kworker/5:1-773 [005] .... 85.973833: rtos_queue_send_failed: tstamp:2926847858 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.973834: rtos_queue_send_from_isr_failed: tstamp:2926848915 queue:0x0b4a7698
kworker/5:1-773 [005] .... 85.973834: rtos_queue_send_from_isr_failed: tstamp:2926849021 queue:0x0b4ab1a8
kworker/5:1-773 [005] .... 85.973835: rtos_queue_send_from_isr_failed: tstamp:2926849128 queue:0x0b4acdd8
kworker/5:1-773 [005] .... 85.973835: rtos_queue_send_from_isr_failed: tstamp:2926849235 queue:0x0b4af718
kworker/5:1-773 [005] .... 85.973836: rtos_queue_send_from_isr_failed: tstamp:2926849339 queue:0x0b4b04d8
kworker/5:1-773 [005] .... 85.973836: rtos_queue_send_from_isr_failed: tstamp:2926849443 queue:0x0b4b1298
kworker/5:1-773 [005] .... 85.973837: rtos_queue_send_from_isr_failed: tstamp:2926849548 queue:0x0b4b2058
kworker/5:1-773 [005] .... 85.973838: rtos_queue_send_failed: tstamp:2926849973 queue:0x0b4a7698
v4l2-ctl-11997 [000] .... 86.001878: tegra_channel_set_power: imx415 9-001a : 0x0
v4l2-ctl-11997 [000] .... 86.001883: camera_common_s_power: status : 0x0
v4l2-ctl-11997 [003] .... 86.002339: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
v4l2-ctl-11997 [003] .... 86.002342: csi_s_power: enable : 0x0
kworker/5:1-773 [005] .... 86.029803: rtos_queue_peek_from_isr_failed: tstamp:2927192347 queue:0x0b4b4940
kworker/5:1-773 [005] .... 86.141779: rtos_queue_peek_from_isr_failed: tstamp:2932192337 queue:0x0b4b4940
kworker/5:1-773 [005] .... 86.313783: rtos_queue_peek_from_isr_failed: tstamp:2937192330 queue:0x0b4b4940
kworker/5:1-773 [005] .... 86.485790: rtos_queue_peek_from_isr_failed: tstamp:2942192321 queue:0x0b4b4940
kworker/5:1-773 [005] .... 86.653801: rtos_queue_peek_from_isr_failed: tstamp:2947192315 queue:0x0b4b4940
kworker/5:1-773 [005] .... 86.821783: rtos_queue_peek_from_isr_failed: tstamp:2952192309 queue:0x0b4b4940
kworker/5:1-773 [005] .... 86.989800: rtos_queue_peek_from_isr_failed: tstamp:2957192302 queue:0x0b4b4940
kworker/5:1-773 [005] .... 87.101778: rtos_queue_peek_from_isr_failed: tstamp:2962192296 queue:0x0b4b4940
kworker/5:1-773 [005] .... 87.269805: rtos_queue_peek_from_isr_failed: tstamp:2967192294 queue:0x0b4b4940
kworker/5:1-773 [005] .... 87.437804: rtos_queue_peek_from_isr_failed: tstamp:2972192280 queue:0x0b4b4940
kworker/5:1-773 [005] .... 87.605795: rtos_queue_peek_from_isr_failed: tstamp:2977192274 queue:0x0b4b4940
kworker/5:1-773 [005] .... 87.773780: rtos_queue_peek_from_isr_failed: tstamp:2982192269 queue:0x0b4b4940
kworker/5:1-773 [005] .... 87.945775: rtos_queue_peek_from_isr_failed: tstamp:2987192260 queue:0x0b4b4940
kworker/5:1-773 [005] .... 88.057787: rtos_queue_peek_from_isr_failed: tstamp:2992192255 queue:0x0b4b4940
kworker/5:1-773 [005] .... 88.225788: rtos_queue_peek_from_isr_failed: tstamp:2997192256 queue:0x0b4b4940
kworker/5:2-1163 [005] .... 88.393800: rtos_queue_peek_from_isr_failed: tstamp:3002192240 queue:0x0b4b4940
kworker/5:1-773 [005] .... 88.561797: rtos_queue_peek_from_isr_failed: tstamp:3007192234 queue:0x0b4b4940
kworker/5:2-1163 [005] .... 88.729778: rtos_queue_peek_from_isr_failed: tstamp:3012192228 queue:0x0b4b4940
kworker/5:1-773 [005] .... 88.901817: rtos_queue_peek_from_isr_failed: tstamp:3017192221 queue:0x0b4b4940
kworker/5:1-773 [005] .... 89.017819: rtos_queue_peek_from_isr_failed: tstamp:3022192213 queue:0x0b4b4940
kworker/5:1-773 [005] .... 89.189774: rtos_queue_peek_from_isr_failed: tstamp:3027192204 queue:0x0b4b4940
kworker/5:1-773 [005] .... 89.357785: rtos_queue_peek_from_isr_failed: tstamp:3032192199 queue:0x0b4b4940
kworker/5:1-773 [005] .... 89.525795: rtos_queue_peek_from_isr_failed: tstamp:3037192193 queue:0x0b4b4940
kworker/5:1-773 [005] .... 89.693819: rtos_queue_peek_from_isr_failed: tstamp:3042192187 queue:0x0b4b4940
kworker/5:1-773 [005] .... 89.861989: rtos_queue_peek_from_isr_failed: tstamp:3047192179 queue:0x0b4b4940
kworker/5:1-773 [005] .... 90.029800: rtos_queue_peek_from_isr_failed: tstamp:3052192173 queue:0x0b4b4940
kworker/5:1-773 [005] .... 90.141787: rtos_queue_peek_from_isr_failed: tstamp:3057192164 queue:0x0b4b4940
kworker/5:1-773 [005] .... 90.309803: rtos_queue_peek_from_isr_failed: tstamp:3062192157 queue:0x0b4b4940
kworker/5:1-773 [005] .... 90.481770: rtos_queue_peek_from_isr_failed: tstamp:3067192151 queue:0x0b4b4940
kworker/5:1-773 [005] .... 90.649807: rtos_queue_peek_from_isr_failed: tstamp:3072192146 queue:0x0b4b4940
kworker/5:1-773 [005] .... 90.821803: rtos_queue_peek_from_isr_failed: tstamp:3077192140 queue:0x0b4b4940
kworker/5:1-773 [005] .... 90.989793: rtos_queue_peek_from_isr_failed: tstamp:3082192132 queue:0x0b4b4940
kworker/5:1-773 [005] .... 90.989796: rtos_queue_peek_from_isr_failed: tstamp:3083121878 queue:0x0b4b4940
Here is my device tree configuration:
mode0 {
mclk_khz = "24000";
num_lanes = "4";
tegra_sinterface = "serial_e";
phy_mode = "DPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "270000";
active_w = "3840";
active_h = "2160";
mode_type = "bayer";
pixel_phase = "rggb";
readout_orientation = "0";
dynamic_pixel_bit_depth = "10";
csi_pixel_bit_depth = "10";
line_length = "2250";
inherent_gain = "1";
mclk_multiplier = "12";
pix_clk_hz = "288000000";
gain_factor = "1000000";
min_gain_val = "1000000";
max_gain_val = "72000000";
step_gain_val = "300000";
default_gain = "1000000";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "30000000";
max_framerate = "30000000";
step_framerate = "1";
default_framerate= "30000000";
exposure_factor = "1";
min_exp_time = "16609";
max_exp_time = "1000000";
step_exp_time = "1";
default_exp_time = "16609";/* us */
embedded_metadata_height = "1";
Sensor has output mipi signal, and I have verified that the initialization sequence of sensor is correct through other devices.
Please help me see what may be the cause of this?
