Thanks for your help.
In the file “TX2_Adaptation_Guide”,There’s a section :
Do not re-use and modify the existing NVIDIA® Jetson™ TX2 Developer Kit code without selecting and using your own board name. If you do not use your own board name it will not be obvious to Jetson TX2 users whether the modified source code supports the original Jetson TX2 Developer Kit board or your board…
Does that mean that I need to modify the file “jetson-tx2.conf” under the path “Downloads/nvidia/sdkm_downloads/Linux_for_Tegra” in the sdkmanager download directory? Should I change the file name “jetson-tx2.conf” to something like “star.conf”, or do i need to change the contents of the file “P2771-0000.conf.common” that is pointed to in the “jetson-tx2.conf” file?
By the way,In the file “TX2_Adaptation_Guide”,There’s another section :
You must also select a similarly-constructed vendor name. The same character set rules
apply, such as the following example:
nvidia
